Old 11-28-2009, 07:24 PM
New Aftermarket Rods
Adds 20 whp per cylinder!!! 3.6L technology applied to EG33 Rod.
If you wanted phast, now you has.
Old 11-28-2009, 07:28 PM
SomethingElse's Avatar
word words wording
Re: New Aftermarket Rods
Sweet mod man! how did you find it?
Eric
Old 11-28-2009, 07:34 PM
Wouldn't you like to know!
J-Spec engineering is off limits to prying eyes.
Old 11-28-2009, 07:36 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Sweet! So much for having to offset grind the crank!
-Bill
p.s. was this in the ill-fated EG33 from the last Cumberland airfield autoX?
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-28-2009, 08:03 PM
This was out of Hocrest's engine. Crank is screwed as it spun two rod bearings and is likely bent by this little gem. This was the #2 rod while the spun bearings were on 4&5. The engine rattled the bolts loose on the back of the oil pump and likely bled out the oil pressure and thus... bad things happen.
Old 11-28-2009, 08:10 PM
Coool...
Can I have that one back?
Old 11-28-2009, 08:13 PM
No, I am prob gonna have it chromed and hang it on the fail post on the lift If you want it, its urz
Old 11-28-2009, 08:32 PM
SVXRide's Avatar
He obviously wasn't wearing his body condom when this happened....
-Bill
Old 11-29-2009, 11:22 AM
-Bill
His trans wasn't wearing its 4th gear either
Old 11-29-2009, 12:00 PM
subeman90's Avatar
Soobologist
is that the engine that was in the car the time you SVX went through the deep water with melis driving?
15 OBW premium w/eyesight
Old 11-29-2009, 01:26 PM
Yeah, but I think it was running it on the highway without 4th for about an hour that did it in...
Old 11-29-2009, 01:32 PM
water would make more sense to the rod the bearings were due to the high revs.
Old 11-29-2009, 03:03 PM
subeman90's Avatar
Soobologist
there is so much win in this statement!
Old 11-29-2009, 03:20 PM
-Bill
No, he was wearing this....
Old 11-29-2009, 04:44 PM
Wow.... Back when I had hair
