Old 11-13-2009, 12:37 PM
CANDU238 CANDU238 is offline
No AWD
Does anyone have a picture of the "C" solenoid installed or on its own? A proceedure for replacement maybe? And also where can I buy one if it is pooched?
When the car is jacked off the ground I can freely rotate the rear wheels by turning the drive shaft.
I also check and the FWD fuse is not in place, as it should be.
Could it be clutch in the rear of the tranny? and again where could I get one.
Thanks
Old 11-13-2009, 02:36 PM
Re: No AWD
When the car is jacked off the ground I can freely rotate the rear wheels by turning the drive shaft.I also check and the FWD fuse is not in place, as it should be.
Thanks
You SHOULD be able to turn the driveshaft on an AWD automatic SVX when the rear wheels are in the air.
In park, neutral,
and if the engine is off, even in drive or reverse.
