Old 11-11-2009, 11:09 AM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
underhood wiring diagram?
hi folks!
i've tried searching the site to no avail...i need to see a copy of the underhood wiring diagram...
i have a moderately thick black wire with a red stripe at the rear-centre of the engine directly above the trans/engine mating surface...
it is broken and i cant find where it goes! (it appears to have had a "ring end" connector that has broken off )
i have just removed all the a/c stuff underhood (likely how the wire was broken )
i also found a failed harmonic balancer, which i replaced with a stock unit.
upon reassembly of everything, the car wont start...grrrrrrrrrrrrr!!!!!!!!!!!!!
there is power to the starter solenoid and when i cross the poles, the starter spins, but the solenoid wont engage the gear to the engine...
this broken wire reaches the starter easily enough...but i dont see the remnants of a broken ring-end connector on the starter....
when i turn the key, the starter doesnt even spin...NOTHING happens at the starter, but EVERYTHING else in the car appears to work fine...
i tried in park and neutral to no avail either....
ive checked all fuses/relays/ the fusible link/ connections between alternator/battery/starter......
helppppppppppppppp!!!!!!!!!!!!
thank u for your time
rob
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 11-11-2009, 11:27 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: underhood wiring diagram?
That sounds like an engine/chassis ground......
You can find a diagram in the link in my signature either by viewing it on the web or downloading it and opening the .pdf labeled "system wiring diagrams". Hope it helps!
Old 11-11-2009, 01:07 PM
yeah...i figured as such...thanks!!
i figured out my no-start trouble...the wire had slipped off the spade lug on the solenoid and i hadnt noticed....D'OH !!!
right with the black wire i mentioned is a broken ground wire bolted to the firewall...it is unplugged and would SEEM like it should match up with the broken black/red...but it doesnt ...
weird...
ps...error 404 file not found...dang !!!
linky no worky at this time...
rob
Old 11-11-2009, 02:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Looks like Scott moved the link..... try here:
http://www.seccs.org/tech/1992%20SVX/index.html
Old 11-12-2009, 01:43 PM
kewl !!
thanks maaaannnn!!!!!!!!!!1
rob
