HELP! stripping torque converter bolts!
im trying to remove the 4 TC volts through the access hole, but no matter what, the wrench/socket just skips off! on all 4 bolts! 1986Nate suggested extractors, and thats my next shot after work tomorrow, but im afraid i wont have the room to get them on the bolts and get a wrench in there along with them. any other ideas, just in case that doesnt work?! im kind of lost here, everything else on the stock trans removal has been problem free, except for this PLEASE HELP
Re: HELP! stripping torque converter bolts!
If you pull the alternator and use a long extension, you can put more force against the socket. If your not already using a 6 point socket and the bolts aren't too damaged, switch to a 6 point.
Costco sells really great "box end" ratchets, in sets, that are tougher than you think. You can use a cheater with it also, just keep it all the way on the bolt!
Keith |
thanks a bunch guys! Turns out 1986Nate actually sent the extentions tip but i didnt notice it on my phone. luckily, my alternators already out! with luck, by tomorrow night the trans will be in, only needing to rebuild the cv's, and hopefully get the beads on the stock rims fixed to get it on the road!!
YEAH! So excited! |
Agreed, if alternator is out, use long extensions and only 6-point socket. If corners are damaged, and that happens, get a socket that grabs the flat between the corners. Good luck
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
i was having that issue too but i somehow using a 12point socket got enough grip for me to get it off
Tranny goes in, tranny comes out, tranny goes in.....AW ****, tranny comes out.... |
That's a relief, removing those bolts is a must
mmhmm i actually replaced the bolts with bolts from the oilpan bolts from my friend's 4Runner. works like a charm.
oh, update, i went to my moms for my lunch brake, and used extensions under the manifold. worked like a charm! i didnt eat till i got off work that day, and i was really hungry, but i was satisfied that there were no problems removing them in the end!! thanks to all!
This is THE WAY to do this!
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
