Old 10-15-2009, 02:59 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
turbo...help
ok, so i have finally set my mind to turbo my car...i think
is it worth the money to tubro the svx or just a waste?
i like to go the strip and i figured if i bout a STI i'll spend roughly 15k....with the same amount of money i can build the svx with turbo, 6mt, and awd. so i asked myself if my svx was built and cost the same as an STI, what would i rather drive. i said svx cause its more rare....
so, can anyone tell me prices and parts for a turbo build? ive looked through the turbo thread and not many prices were shown....
VICSVX
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 10-15-2009, 04:53 PM
Re: turbo...help
You need to do a bit more research. For a proper turbo build you will not only need the turbo system (which has to be fully custom built because there is no kit for the SVX), you'll need to build the engine to take the boost (forged low compression pistons, rods, head work, etc), and figure out some engine management (Hydra Nemesis in the $1500 range). As you said the 6MT swap as well, which typically runs $5500+. Not saying it's a waste to turbo an SVX, it has been done successfully, but it's not an easy road.
Old 10-16-2009, 09:38 AM
VICSVX's Avatar
Never Forget
Re: turbo...help
yes, i know the engine build..but not sure where everyone is getting their parts and how much they alll cost.
and what i ment if its a waste to turbo is does the car perform a lot better then stock or barely?
VICSVX
Old 10-16-2009, 12:39 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: turbo...help
ask Paynter, he recently did his own custom turbo
Old 10-18-2009, 06:57 AM
longassname's Avatar
Just some dude.
Re: turbo...help
A performance tcu and performance valve body will take care of the transmission needs.
The aggressive version of stage 2 flex software can run e85 and will take care of the engine management and aftercooling needs.
A car with that is ready for a pair of garrett gt2259 turbos--one mounted under each cyllinder head directly on new exhaust manifolds.
VICSVX
Old 10-18-2009, 09:09 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: turbo...help
Phast seems to be doing it up on a stock motor with the tun LANs talking about. If my car had a running motor when I got it I'd have probably gone that route too.
Old 10-18-2009, 09:40 AM
Just some dude.
Re: turbo...help
Actually phil is still running 2v7. The "aggressive" version which I will soon be replacing 2v7 with should prove even/much better. It starts all in on the timing instead of relying on the knock sensors to learn in timing.
Old 10-20-2009, 08:57 AM
the_paynter the_paynter is offline
Re: turbo...help
the normal 2V7 works very good as well and I had a lot of fun with it. I drove for 5000kms on my setup (everything still looks brand new haha) and had no issues except for a head gasket which was already on the way out anyways.
The car is a BLAST at 8psi on a Garret 60-1 and with the 2v7 my AFR was high 10s to low 11s. ECUtune really makes a great product.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 10-20-2009, 02:08 PM
VICSVX's Avatar
Never Forget
Re: turbo...help
so, sounds like the turbo was worth the work and money?
can you tell me prices and where you got your parts for the build? i have 10k saved up right now and want to start buying parts but not sure where to get parts. can you provide a list of the parts, where you got them, and prices?
VICSVX
Old 10-20-2009, 05:05 PM
Re: turbo...help
PM'd you
Old 10-20-2009, 05:16 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Re: turbo...help
bump for a great product.
Mike, and word timing? I am looking to schedule some dynotime this winter.
~Phil
Old 10-24-2009, 07:07 AM
Just some dude.
Re: turbo...help
I could send you one right away.
Old 10-24-2009, 04:01 PM
Phast SVX's Avatar
Re: turbo...help
Ok cool. I will chat with the shop that has the AWD dynojet in green bay here and see what their early december looks like, so i am all moved in to the new house and settled.
~Phil
