Old 09-29-2009, 09:22 PM
Invisible avatar
Question Any garage door enthusiasts out there?
The rolling cover that keeps the Batmobile safe from roving bands of Cash for Clunker raiders, has failed me. This thing was here when I bought the house 25 years ago, & has done what I've paid it to do (go up & down faithfully) ever since, until last week. I came home from a week-long trip, pushed the remote button, & hear nothing but a grrrr sound. Turns out she'll go down just fine, but won't reverse. I fiddled with all the mechanical "start-stop" hardware, which works fine. The motor simply won't reverse. I even called the Genie help line, & talked with a gal who had me climb a stepladder & play with a few connections, after which she she proclaimed it officially kaput. I'd replaced the receiver, the box with the dangling antenna wire, about three years ago, because the remotes ceased to function, & all was fine 'til now. There's a printed circuit board mounted inside the motor housing, & I'm assuming that where the problem lies....but I can't prove it! So, if there there are any mechanically inclined folks in here who can tell me what to bang on with a big hammer, I'd love to save my Genie from the scrap heap. I can buy a lot o' boxed wine for the price of a new unit. It's a model 450 screw drive tugging on a 2 car wooden single door.
Thankew, Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 09-29-2009, 10:47 PM
Re: Any garage door enthusiasts out there?
be glad it lasted that long. mine is probably that old, too, but moving to a new house next month with a two car garage ..... and one opener. i'll have to add one.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 09-29-2009, 11:29 PM
Thankew, Ron.
Well Ron, my Genie grants me 3 wishes and I would wish for my door to work again!
My second wish would be for a couple more boxes of wine,
and the last wish - 3 more wishes!
Old 10-01-2009, 03:46 AM
Francis Francis is offline
ive worked into garage doors for about 2 years , i would suggest u changing your motor. since you want to start working on changing the printed circuit board , estimated price of 100$ , tell yourself that for 300$ more you get a brand new motor that will end in another 25 years...
maybe your door springs are broken, and motors having problem opening it because the door is too heavy either the motor is burnt,
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 10-01-2009, 05:01 AM
Ron you old bugger, I have to give my very best attention for sure, when the $hit hits your fan.
First thought --- Does not appear too expensive as it closes, but does not reverse, but I gather does grunt/try in reverse. The previous post suggesting a balance spring problem makes good sense. Give it a helping hand when you give it the necessary, and observe all of the mechanical stuff involved.
Whatever you can fix it. Don’t panic. Follow your nose. Do not use that big hammer. Contemplate and open one or two. Report your findings here for plan B, which may involve shocking electric stuff. Meantime, howsat for now.
Thanks will be due only when the old girl can lift her skirt.
Old Fart.
Old 10-01-2009, 05:55 AM
for ~$150-200, he can have a brand new opener.
Old 10-01-2009, 09:38 AM
BoxerFanatic's Avatar
My garage door opener snapped a spring a couple months back.
Would go down fine, but was extremely heavy going UP, fighting against the spring wound the other way. The two springs are wound to cancel each other out, and strong enough in both directions to make the door's weight be minimal.
If one breaks, you not only get the full weight of the door, but the counter-force of the opposing spring. A garage door opener will burn it's motor out fighting that much force.
Just as mine did. I had to get the spring replaced, and the motor drive. It just depends if you want another Genie, which IIRC are screw-drive, or some other chain-drive unit. My chain drive unit was about 150$ with new motor, new remotes, and even a new chain and guide which I didn't need to replace.
But if you use the same system, by replacing it with a new unit, you get more remotes as well, as chances are your existing remotes, and your new remotes in the box, will both probably work.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 10-01-2009, 11:58 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
EZ test:
Pull the release so the door goes up and down manually. Observe smoothness of glide during up and down motion, and relative weight of door. If its ok, then discount any problem with spring or rollers.
Then operate motor while door is still disconnected, if it still does not move in reverse, motor is kaput. If it does go in reverse, allow it to go through up and down motions a few times, then reconnect door and try operation with load of door on motor. If it still does not reverse under load, motor is kaput.
Old 10-01-2009, 05:15 PM
yah well, depends on the brand and here in canada , for 450 $ CAN it is brand new 1 year warranty and the guy come install it. for a 3\4 hp
rest in pieces
Old 10-01-2009, 06:44 PM
Get a belt driven one as opposed to chain... Belt is much quieter which is very handy if your garage is attached to the house
Old 10-01-2009, 07:04 PM
Old Fogey
WORD!! Belt-drive are the way to go. Quieter than screw-drive too.
Glenn
Old 10-02-2009, 01:25 AM
true , buy it only if it is connected to house...
Glenn
rest in pieces
Old 10-05-2009, 09:07 AM
Invisible avatar
Thumbs down Re: Any garage door enthusiasts out there?
Upon furthur review, a la Google, the problem probably lies within the internal motor circuit board called the sequencer. A replacement for my relic doesn't seem to exist anymore, & if it did they cost around 50-60 bucks. So....I guess it's time to hit Lowes, & dump a coupla' hundred into a new contraption. I may even pay a grunt to install the thing, as retirement has resulted in an extreme case of personal laziness. Thanks to all for commenting upon my delimma - even to certain old farts residing below the equator.
Ron.
'01 Miata SE - 79K
Old 10-05-2009, 06:59 PM
Ron.
OK Ron,
I will respond at maximum volume and you may receive audible confirm of this message. Better pinch your nose just in case..
Old Fart down under,
