Old 08-05-2009, 05:11 PM
Mephis Mephis is offline
Door Panel won't come off...
Taken out the 5 screws and already put some good sized cracks in things trying to pull up and pull it out as noted on the previous threads.(also, I have all the clips pulled free at the bottom)
It's wiggling around but it will NOT come off for nothing.
Can anyone please further explain this process because the previous threads must be missing some step?
Problem solved:
There's 3 screws under the arm rest felt as opposed to just two like the how-tos would have you believe.
Old 08-05-2009, 05:29 PM
Re: Door Panel won't come off...
It acts like it's hung up some where between where the front screw in the armrest goes, and the door handle.
I'm still yanking around and trying to figure out what on earth is going on....
Old 08-05-2009, 05:31 PM
redlightningsvx's Avatar
Collision Refinishing Tech
You did remove the screw under the handle right?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-05-2009, 05:32 PM
Yep... The goldish colored one.
It's moving freely-ish. It's just sort of rotating at the point I mentioned and refuses to break free. All along the edges is free, top and bottom is free, I have the lock down inside the door, and I can rotate it over the door handle but I can't get it to pull off.
Anyone have any ideas? I'm having to do this over at a friend's house where I have some room and I'm just refreshing the page in hopes someone knows of something to try.
Old 08-05-2009, 05:50 PM
There are some plugs you have to disconnect for the locks and light.
Seth
Past subies:
Other toys:
Old 08-05-2009, 05:52 PM
There's 6 screws... Not 5.
I just pulled the arm rest support clean out of the metal frame of the door. You guys need to fix your write ups.
Old 08-05-2009, 05:57 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Theres 5 securing the door panel to the door..... I think the 6th screw you're referring to is the one forward of the 2 big ones down in the armrest. It only secures the little plastic piece inside and is not necessary to remove to get the panel off.
Old 08-05-2009, 07:19 PM
Maybe people should mention that some where in the write ups before people like me spend 3 hours trying to get the door off only to discover a 6th screw.
Oh well guess if someone does a search now they'll see this thread.
Old 08-05-2009, 07:26 PM
From someone who has taking there door panels off more than 30 times there is only 5 screws needed to remove the panel.
Seth
Past subies:
Other toys:
Old 08-05-2009, 07:53 PM
immortal_suby's Avatar
Thread Killah
Yep, 5 screws stock. Maybe a previous owner added a screw. The writeup is correct for an unmolested door panel.
Locker Link
2015 BRZ Limited 6MT
Old 08-05-2009, 08:35 PM
the_paynter the_paynter is offline
x2
had mine off a few days ago, there are definitly only 5 required screws.
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 08-05-2009, 09:16 PM
There's places in the molding of the door panel for the 3rd screw in the armrest that looks factory to me.
There's 3 screws under the felt. And nothing anywhere says which 2 are the ones that you have to remove. I assumed the front and the back when it's actually the back and the middle. Who the hell would know this without someone telling them?
Old 08-05-2009, 09:46 PM
There should be only 2 screws under the felt.
Seth
Past subies:
Other toys:
Old 08-05-2009, 10:08 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Theres a 3rd screw, very small, at the very forward part under the felt, but as mentioned, it does not secure the door panel, just the plastic piece.
Old 08-05-2009, 10:13 PM
wyldnwoody44's Avatar
wyldnwoody44 wyldnwoody44 is offline
Mechanically worthless Man : )
Yep theres 6 total, 3 under the felt, ive had my panels off 3 times this week to do some soldering.
-92 Ebony LSL, complete with all the problems
-New self paint job; charcol metallic silver
-4.44 tranny,
Nicknamed the SexVX : )
