Old 07-19-2009, 11:25 PM
Re: My progress so far
Originally Posted by SURTEESS View Post
So did you replace ALL the glass - or was the tint (green) an add-on by previous owner...
It looks like the blue factory tint on all the windows and back glass but it looks like the windshield has the bronze tint.
Old 08-03-2009, 04:49 PM
the_paynter the_paynter is offline
Over the weekend I managed to build the turbo up pipe and 3" downpipe. I ran out of gas while welding the down pipe so the welds are garbage, I will be grinding them down and redoing them this coming weekend along with finishing off the exhaust, and then i will get some video clips.
here is a picture from early saturday (before we finished up). It's currently not boosting as Im waiting for my stage 2 chip but hopefully it will be here tomorrow but for now I just have my intake flipped so I can still drive it to classes (ya ya i know its not good for the turbo but its my only mode of trasnportation and the turbo has been sitting on my shelf for like 3 years anyway. It does have the oil feed and return hooked up though so im not starving it)
my goal is to try and keep the air conditioning because it gets friggen hot here in the summer, right now it seems doable but we'll see.
PS: I know my engine is sitting funny, my drivers side mount is effed, waiting for my new one to come in
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 08-03-2009, 07:17 PM
redlightningsvx's Avatar
Collision Refinishing Tech
You painted the rubber under the leadlighs/grill.... Turbo looks god so far.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-03-2009, 07:49 PM
Haha i know i have a new one to go on, just havnt gotten around to it yet, at the end of my summer semester and lots of exams/assignments due!
Thanks!
Old 08-04-2009, 02:11 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Congrats, car looks better than before!
Have you put the lock back in for your trunk?
How did you open? By remote trunk release?
It seems that front windshield has been replaced.
Looks different color to me.
How was your old tires wear?
Did you need an alignment for the new tires/rim?
Just wonder.
Do you have HID or just the better bulbs?
Did you mind taking some pics at night shot down
the road and face to a wall?
I just wonder how does the cut-off look from the
projectors with the clear lens.
Good luck for the Turbo Project!!
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-04-2009, 07:30 AM
The trunk lock is back in, and I was opening it by the handle in the car on the drives side floor. People have been saying my windshield looks like it was replaced but it has the same code eteched in the windshield as the rest of the panels in the car from when it was imported... I dont know if this is a fluke or if they smashed the windshield and replaced it at the yard before sending the car out
I needed an alingment for the 18's so I did it the same day I put the wheels on. I have driven it to Nova Scotia and back now (3700km round trip) and the wear is normal.
I have an 8000K HID kit in my projectors and I will take some pictures tonight of it facing a wall to show you the cut off!
Thanks!
Just wonder.
Old 08-21-2009, 07:17 PM
Well shes all working now. Im just finishing up the inlet pipe and then I will be done, but it is a blast now.
Old 08-21-2009, 07:59 PM
Wow!!! Nice.
Old 08-21-2009, 08:16 PM
Looks good man, good to see another boosted member amongst us
Old 08-21-2009, 08:59 PM
Gamesy's Avatar
Gamesy Gamesy is offline
I'm gonna have to pick your brain on the setup we should meet up when we're both free
Old 08-21-2009, 10:14 PM
Banned
awesome looks great! please forgive my ignorance, but is that turbo similar in size to the gt40 series turbos?? How much boost do you plan to run??? were you able to keep ac unchanged??? it looks like you moved the battery slightly, how are you mounting it???
Old 08-22-2009, 11:03 AM
The turbo is a little smaller then a gt35r in size. The ac is all retained, the battery is turned and I moved the fuse Box into wheel well, only thing I removed was the washer tank. I'm making 9psi right now.
Old 08-22-2009, 04:32 PM
Banned
how are you running your washer fluid now?? are you running that setup on the stock motor or have you put LCR pistons, new rods, etc in??? Do you plan to get dynoed numbers soon???
Old 08-22-2009, 05:30 PM
Stock internals right now. I have a spare engine I will be building over the winter with forged wiesco pistons, eagle rods, ACL bearings, cams, and supertech valvetrain. Also looking into getting some darton sleeves but we'll see how it goes. Also going to convert to a top feed fuel rail and run 1200cc injectors, Hydra, and Percision billet 6765 turbocharger.
I'm going to be dynoing it in about 2 weeks when The toronto subaru club dyno meet is on.
No washer fluid right now, I just picked up new lines to mount it in the trunk
