Old 06-03-2009, 04:40 PM
Considering these Enkei Rims
They are Enkei 17" 5 bolt universal with a +55 offset (according to the seller) so they sound perfect. They have a 215/45/R17 tires on them, does that mean they are more narrow than the stock SVX tires?
File Type: jpg 3k73p13l6ZZZZZZZZZ95r03924d86340d1353.jpg (8.1 KB, 211 views)
File Type: jpg 3n63k63pfZZZZZZZZZ95rdb56e7479e3b181c.jpg (7.5 KB, 173 views)
Old 06-03-2009, 04:50 PM
Re: Considering these Enkei Rims
Yes and no Sean. It depends which SVX year you mean.
All early SVX cars were fitted with 225 profile tyres. The 96-97 cars came as standard with 215 profiles.
If you are thinking of buying these with tyres fitted, and the tyres are good, I would say go for it. The SVX is AWD and has masses of grip. The 215 tyres will probably make your car go a little faster, because they have less drag.
It's likely though they will have a smaller rolling diameter than what you currently have on. This will make your car accelerate faster, and your clock read fast.
[too high, higher than correct actual speed shown on the speedo]
If the tyres are good and the deal is good, I would go for it, big time.
[Nice wheels man]
Old 06-03-2009, 05:18 PM
Thanks Joe.
Old 06-03-2009, 06:48 PM
NiftySVX NiftySVX is offline
only the 97 had 215s, and they were 215/55/16 so the overall diameter was almost the same. As long as the wheel is at a minumum 7 inch wide you can just slap some 225/45/17s on it. I have 17x7s on mine with that size tire.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 06-03-2009, 06:53 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
By the numbers, the speedometer and actual speed will vary by 1 mph. I figure that's close enough.
Old 06-03-2009, 07:22 PM
Probably not buying them now unless I can buy the rims without the tires. I just heard back from the seller, the tires have more wear on the fronts than the back, so I would not be comfortable using them. Thanks for all the feedback.
