tie rod ....dead
hi , i am suspecting that my passenger tie rod is broken.
when i am crusing around 100-110 km\h my steering wheel heavily shakes . i kicked my tire sideway to see if there is a loose ,unfortunetly it wasn't stiff. i am wondering if it is do-able or should i pay someone to do it , i have many tools but i don't want to be stuck if i fail. since i will have to remove the wheel and get there is there anything else i should check ?for sure i will have to bring the car to the garage for an alignement after fixing this. i read the manual-cd with nothing that could help and the search option the the forums don't take "TIE ROD" so i am asking you . please thanks for hints.
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill |
Re: tie rod ....dead
Are you sure it's the tie rod? When I had a wheel bearing go bad, I know that my wheel wasn't very stiff at all when I kicked it.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
since it is only moving horizontally , i 'd say it is a tie rod. but i do hear a kinda wwwooooooooooommmppppppp noise when i am rolling. you may be right , is there a good way finding what is the problem ?
edit : i know that my car keep pulling me to the right too, but this may be an alignement.
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill Last edited by Francis; 03-21-2009 at 08:08 AM. |
ended with balljoint failure.
damn, i've changed my balljoint , it helped but i notice that it is still loose in the steering rack and i am seriously thinking it is the inner tierod, conductor side, is there any tricks to remove this safely and easily ?
With all due respect, for safety's sake you should immediately take the car to a pro for a proper diagnosis, rather than guessing.
dcb |
my friend was shakin the steering and at the same time i was touching the tie rod and i could feel a loose from the inside..not from the uh galiper... it has to be this
well...i guess i ll jack up the car and go on by myself . i know i will have to send it to the garage for an alignement anyway, its not a question about money . i just like to work on things .
Without an inner tie rod end tool it is quite difficult to change them, you might want to look into renting one (if you even can...not sure). Don't forget to replace the boots and locktite the threads.
thank you for explaining me about rack and pinion , i have seen the part list http://www.subaru-svx.net/photos/files/How-To/28216.jpg and i guess it would be part 7 ? , or when something like this occur, if i still drove it, 3.6.7 would need to be changed ?
EDIT: i have d it. i understand a little more about the tool you were talking about... like u said , that kind of job look alot harder without proper tools, sucks i can't do it by myself , if i want to wait a few weeks i could do it at my uncle's garage, he probably has a "tie rod remover",i ' ll see what i can do, i guess since i'm in it ,i guess it is better to change them both, i hope i will only need to change part 7 .
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008" rest in pieces Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill Last edited by Francis; 05-28-2009 at 09:12 PM. |
Thread Tools | |
Display Modes | |
