Old 03-14-2009, 01:27 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
codes wont clear
ive been going through the process of checking and clearing my codes but they wont clear
the CEL keeps coming on
Ill put the blue wire pin into the second slot from the left in the black connecter with the notch up and the ignition off. then ill turn the ignition to the on position and read the codes (32, 31, 37, 23).
Then ill put both blue wire pins in the first two slots in the black connecter notch up and start the car and turn it off
Ill check the codes again and theyre still there
what am i doing wrong?
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 03-14-2009, 01:48 PM
Re: codes wont clear
Have you investigated the codes? How long has the CEL been on?
Old 03-14-2009, 01:54 PM
tiv0's Avatar
svxless
heres what i have to look into:
31 Throttle Position Sensor or Circuit
32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX)
37 Oxygen Sensor (No. 2, Left Side, On SVX)
23 Pressure Sensor (Justy)
im not very knowlegeable on the layout of the vehicle, that is, where these sensors are
my CEL has been coming on with every drive for probably the last month or so
Trevor
Avondale, AZ
1987 BMW 325is
Old 03-14-2009, 03:05 PM
What I was trying to figure out is if all 4 codes started at the same time or if they've been adding up over time.
If they all happened at once then chances are there's nothing wrong with the sensors and you need to find out how they are all related.
Perhaps there's a bad fuse. I would make sure of this first.
Also check your battery (load test) and charging system (alternator). A weak battery can throw false codes. I've seen it happen personally.
If the above are good then start with the smallest code (23). See if you can borrow a known working MAF sensor to see if it eliminates one or more codes. Work from there.
Old 03-15-2009, 08:54 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Try disconnecting your battery overnight and reconnecting it the next day.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-15-2009, 09:33 AM
kwren's Avatar
kwren kwren is offline
After disconnecting the battery negative cable over night I would touch the disconnected cable to the other cable for a few seconds before reconnecting the negative cable back to the battery. Then before starting the car I would check for codes again. This will verify that the codes have cleared, (maybe) At the verry least it should. These cars are strange animals.
Keith
Old 03-15-2009, 03:53 PM
tiv0's Avatar
svxless
i dont believe they all happened at once
a few weeks ago when i first noticed the light, i checked the codes and only received one for one of the O2 sensors
so yes, they have been adding up
will do
Trevor
Avondale, AZ
1987 BMW 325is
