Old 03-11-2009, 10:07 AM
Jeremy'sSVX's Avatar
Jeremy'sSVX Jeremy'sSVX is offline
Send a message via AIM to Jeremy'sSVX
Question Spring Spacers?
So i just got new murano wheels on my SVX but the rears slightly rub on the outside fender when i hit a bump or corner hard. I still have the stock struts and springs so they're not adjustable at all, and i dont have the money to buy anything major. But I was lookin around the internet and found these:
http://www.autoanything.com/suspensi...A2933A0A0.aspx
http://www.jcwhitney.com/autoparts/I...=group_listing
http://www.jegs.com/i/Mr.+Gasket/720/1285/10002/-1
Has anyone had any experience with any of these? Or any other suggestions that i could do to raise my car about an inch?
Thanks,
Jeremy
-Jeremy-
1994 Barcelona Red LS 97,xxx miles
- JVC Indash head unit, polk 6.5's, 6X9's, 2" tweeters, and 8" JL audio subwoofer run off of MA Audio M589I amp. Fiberglass Front splitters molded in, Shifted back stock spoiler, & repainted minor faded parts (Mirrors, rear quarter garnishes),18" murano 5-spoke wheels w/cooper zeon 2xs tires, '97 grille
Old 03-11-2009, 10:25 AM
Re: Spring Spacers?
Should work, but I wouldn't count on those as a permanent solution. The ideal thing would be to go to a stiffer spring with the same ride height and limit suspension travel over bumps.
If I ever do get around to fitting STi suspension into my car, I may look into also fitting Forester suspension for winter, to lift it up and give me some extra ground clearance
Old 03-11-2009, 10:30 AM
Re: Spring Spacers?
Do you know off hand what the diameter of our stock springs are? I can't get in behind the wheel to measure it.
-Jeremy-
Old 03-11-2009, 10:41 AM
Re: Spring Spacers?
No, sorry. I'm sure there's someone who can tell you, or at least someone who has a spring out of the car that they can measure.
Old 03-11-2009, 11:12 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Spring Spacers?
They'll raise it but will also take a link out of action for the suspension which will make your springs weaker and then you'll be more likely to rub over bumps. You're better off making a spacer which goes atop or at the bottom of the spring between the collar or top mount and the spring.
Old 03-11-2009, 03:56 PM
Re: Spring Spacers?
I think that's what the first one is, you can see there's a notch for the end of the spring. Putting it back together will be a pain though, you're going to have to heavily compress the spring just to get that nut on.
