Old 02-23-2009, 06:55 PM
RoughSilver92 RoughSilver92 is offline
Cover between engine and transmission
My 5 speed is now bolted to the engine, and I have no cover plate to cover that gaping hole at the bottom. I could not find any pictures showing a cover on the svx at subaruparts.com, and I don't know if the one that fits the car my transmission is out of (2006 impreza 2.5i) will fit if I order it. Does the svx even have such a plate? I see holes so I assume there was one at some time. What is everybody else using on their 5mt swaps?
On a related issue, there were also no dowels in the block on the transmission mounting surface. If there are supposed to be alignment dowels am I at risk shearing the 4 transmission bolts without them?
Old 02-23-2009, 08:11 PM
Re: Cover between engine and transmission
Without the bolts in the autos, it will cause the flexplate to crack. Not sure about the effects it might have on the flywheel of a manual, Shouldn't shear the regular transmission bolts off though.
There is a plastic cover that goes on the bottom between the the engine and trans but not sure if the same one will bolt to the manual. Only thing it prevents is water getting into the flywheel which would eventually cause it to surface rust but not affect the structural integrity of the flywheel.
Old 02-23-2009, 11:02 PM
If it was still an auto, I wouldn't even worry about the cover, a little water and dirt on the torque converter doesn't scare me. It's water and dirt in the clutch that I'm not exited about. In my mind it just seems like a bad thing. I'll probably just try the one for the 06 and hope it bolts to the block. If not it's only $13 and I can't seem to find the p/n for the svx cover.
Old 02-24-2009, 12:01 AM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
If it's any consolation, my WRX doesn't have any cover at the bottom of the clutch. Something's gotta let all that clutch dust and smoke out!
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
