Old 03-01-2009, 07:32 PM
Brandon770's Avatar
Brandon770 Brandon770 is offline
Smile Re: HELP!! 1996 svx 4EAT question
Thank you every one for the help. I have purchased a 1997 donor car for my swap and will be starting This coming Friday.... Yay.. can't wait. Consider this post closed. Every one is awsome!!! Thanks again!!!!:
Old 03-01-2009, 08:46 PM
Closed, NO! We want to know what the results are. When you get it fixed, please post back here with your thoughts and problems if any. Thanks
Old 03-02-2009, 03:05 AM
I'm glad you got an SVX tranny for the replacement. Legacy transmissions work OK, but as the guys indicated above, if the wiring runs a different colour system it will make it difficult to wire to the existing SVX connectors.
Not impossible, mind, just very, very difficult.
Just to add a little information; They list that Jersey gearbox as being from an EG25. Assuming this is correct, you can make a couple of deductions based on that. The first is, for the period mentioned it will be most likely from a Legacy Outback, Japanese variant. [In Japan there was also a Forester 2.5 on sale, but these are rare beasts, the 2.0 turbo is the most common Forester]
In turn either of these options will imply that this 4EAT is what the Japanese call the Active Torque Split AWD gearbox. This is good news, because it is the same type auto used in US model SVXes. It has the rear drive electric clutch, plus VSS2 is wired exiting from the front differential near the dipstick to feed the speedo, same as US models.
If this gearbox had come from a 2.0 car [EG20] then there are two possible auto types, the US type same as above for non-turbo cars, or the VTD type that was fitted to turbo cars. The VTD type 'box is different, it has VSS2 wired internally and exiting via the left hand cord, and so needs a dedicated TCU.
Let us know how the '97 swap goes; the '97 auto will have the benefit of all factory upgrades, and it ought to be plug and play.
Best of luck with it.
Old 03-05-2009, 11:20 PM
Brandon770's Avatar
Thanks for all the replies guys. I forgot to mention that the donor car was a 5 speed and I am doing a manual swap!!!! I start tomorrow!!! YEAH!!!!! Picked up the car for 600$ on craigslist.com. The tranny is in great shape and shifts perfect every time. I even took it out rallying for a few hours just for fun!!! Wow I'm still way too young lol. Thanks for the replies every one. I appreciate the help a lot. I will try to keep posted pictures of the process and for every one to see!!!
