Old 02-20-2009, 06:31 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Rear diff ratio's for 5 speed swap
I just bought an 05 WRX transmission the other day, I was asked if I also needed the rear and I told him no because my car has some rear diff in it already and I knew it had an WRX trans in it for a while so I assumed it was a 3.90. Upon asking the previous owner he says its a stock SVX rear but that the ratio is the same as the WRX... But from what I've found so far the rear of an SVX is 3.55. Is this correct? Do I need to go back and buy the rear diff or is he correct and I sould save my money?
Old 02-20-2009, 07:37 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Rear diff ratio's for 5 speed swap
If I remember correctly the center diff of a WRX transmission has a 1.1 to 1 stepdown, so they use a 3.54 R160.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-20-2009, 02:50 PM
laserx's Avatar
laserx laserx is offline
When my son did his conversion (I paid for the parts) I bought a 2004 WRX tranny and rear diff. My son swapped both and then found that the SVX axles would not fit in correctly, and found that the SVX rear diff worked perfectly...so now I'm stuck with a 2004 rear diff and no use for it. I believe the 2005 is exactly the same so stick with your SVX rear diff.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 02-22-2009, 10:34 AM
Thanks, saved me 70 bucks =)
Minor problem with the tranny, it has a mounting stud broke off... Can I replace that pretty easily?
