Old 02-11-2009, 11:38 AM
jcimos's Avatar
jcimos jcimos is offline
My SVx is not as fast as I thought....
I wasn't sure if Technical was the best place to ask this question, so here i go anyway. When I got my car it was for the looks not really for the muscle. The Svx has 230hp right? Why does mine feel like it has 130hp. Is the svx tunable? What do i need to start doing to build up the motor?
jcimos
Old 02-11-2009, 11:41 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: My SVx is not as fast as I thought....
Welcome to the Network family! There are plenty of existing threads that will directly address your questions. Just let the "Search" feature be your friend.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-11-2009, 11:57 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
jcimos
Dont forget the SVX is obese.... like 3500lbs. The first thing id check is the easiest... the air filter. Also you ARE using premium fuel right?? Lower grade fuel will make the ECU retard the timing and enrich the mixture to prevent knocking.... and reduce power noticably. If not those things.... there may be tougher to find issues such as timing belt slippage or sensor malfunctions. No check engine light on?
Old 02-11-2009, 11:58 AM
Hondasucks's Avatar
Subaru Technician
Main reason is it's 230 HP in a nearly-4000lb car with AWD, an automatic transmission, and a 3.54 final drive ratio. Good for cruising comfortably on the highway, and having enough power to still be fun, but a rocketship it is not.
There are ways to tune it up, the search function will benefit you greatly!
1986 VW Jetta
Old 02-11-2009, 12:22 PM
One thing you will find if you intend to up the power of the car beyond stock, well running, HP levels, is that the cost increases almost exponentially the farther you go. Intake and exhaust might get you up to ~250 HP, but even that will likely cost you $1500, and then you'll max out your stock MAF. That means it's either time for an ECUTune chip, or a manual transmission swap and Hydra engine management. Now you're well into the thousands of dollars. It goes on from there.
The realistic fact is, if you want something that will leave clouds of tire smoke at will, buy a different car. Getting more power out of this one is incredibly tedious and expensive.
Old 02-11-2009, 12:38 PM
jcimos's Avatar
Okay, well this is whats in my svx already. It has a 5 speed wrx tranny, dual exhaust MegaFlow system, fuel pressure regulator, and a SAFAC II module. I always try to put premium and when i use mid grade I add octane booster. The check engine light is on and it is read code 23, something to do with my mass airflow senor i believe. Besides that no real tune. Could it be my SAFAC II needs to be tuned?
Jcimos
Old 02-11-2009, 12:50 PM
sicksubie's Avatar
SAFAC are you using and how did you get it to work with the SVX? I have never heard of anyone using one on a SVX.... BTW if you are throwing a code for a faulty MAF that would affect your performance tremendously....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-11-2009, 12:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Yeah your MAF code would be the absolute first place to start. Thats the holy grail of air/fuel management for the fuel injection system.
Old 02-11-2009, 01:02 PM
jcimos's Avatar
I not going to lie to you guys, the previous owner went to a tuning shop and had it installed. Do i need to replace my MAF or just the pig tail to get rid of that code. Or should i just clean it?
Old 02-11-2009, 01:08 PM
sicksubie's Avatar
try cleaning it and frankly I would be tempted to pull that safc out completely. You dont want to add complicated variables to a problem...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-11-2009, 04:03 PM
Jcimos
What year and color is this car? Just wondering if I knew a previous owner...
Old 02-11-2009, 05:36 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
This, of course, makes it amazingly worth it in the end...
Old 02-11-2009, 07:46 PM
newsvx's Avatar
newsvx newsvx is offline
Send a message via Yahoo to newsvx
Okay, what's a SAFAC?????
Harry
newsvx
1992 SVX LSL, #1215
1997 SVX LSi, #370
"I live with fear every day. Sometimes she lets me go racing."
"Getting Older and Slower"
Locker: http://www.subaru-svx.net/photos/user.php?newsvx
Old 02-11-2009, 07:54 PM
SuberNatural SuberNatural is offline
SAFAC = poor man's tuing and usually lead to a dead motor due to running too lean, etc.
OP, do a general tune-up on the car... plugs, etc.. (or at least inspect them)
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 02-11-2009, 07:55 PM
If I had the money.....Maybe that should be the network's slogan?
