Old 01-28-2009, 07:42 AM
stuartracing stuartracing is offline
Re: Rearend noises...
Originally Posted by oab_au View Post
You can.clear the TCU codes by pulling fuse No.14, in the fuse box under the dash, for 1 minute.
Thankyou for the tip....I will check it out...
Much appreciated....
Just came in from checking my fuse panel under the dash....Is #14 fuse the one with a yellow guard around it???I don`t have a numbering diagram to make sure...Or just count left to right to #14th fuse....
Old 01-28-2009, 02:52 PM
Mine is a RHD so as I see it, it is in the middle row closes to the door. I think it is marked AT. Yours maybe back to front.
Old 01-28-2009, 03:23 PM
Yes that`s the right one on my car....It looks different than all the others with a guard over it like your not supposed to mess with it... Oooh, right hand drive, that must be fun or are all the cars there the same....
Thanks Harvey....
Old 01-28-2009, 03:49 PM
Thanks Harvey....
The one with the yellow cover is the Air bag fuse. It's the one at the other end of the middle row. It is marked " AT UNIT" on mine.
Yes Australia is always right.
Old 01-28-2009, 04:04 PM
Yes Australia is always right...
Oh ok, your RIGHT....I`ll go out before it gets dark out and check it out....
Old 01-28-2009, 04:29 PM
I pulled the fuse to clear codes...Did a re-test and the power light blinks steady now....Haven`t driven it yet, but is that when the codes will come back if there is anything wrong with the trans.??? I don`t have a plate for the car so I have to wait for the right time to test ride...
Old 01-29-2009, 02:38 PM
Took the car for a ride and the same codes came back...So at least I know what needs to be fixed now....Going to bring it a trans. shop and see if they will fix those and adjust the brake bands for a decent price....
On a long road 60 to 70 mph, it doesn`t want to stay in 4th or overdrive....
And the rearend isn`t making the weird noises much any more after clearing the trans, codes....
