Old 01-19-2009, 07:29 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
header bolts snapped, tourque converter bolts!!!urgg
ok so as alot of you know i am STILL in the mits of changing my front differential, now i took the exhaust down and the header bolts snapped off.. would the easiest way be to drill them out and put bolts and nuts on them? i was looking and it looks like that will work out ok? and is there a special way to get the torque converter bolts back in....man o man are they a pain.. and are they all different sizes?
thanks, bobby
Old 01-19-2009, 11:10 PM
svxpert svxpert is offline
Re: header bolts snapped, tourque converter bolts!!!urgg
your header bolt broke off in the head? if so, you can drill it out carefully then get a new stud. as for the torque coverter bolts, there should be 4 all the same size. just use a 1/4 socket to get them started the switch to a 3/8 drive to tighten them.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 01-20-2009, 09:10 AM
Green1995SVX's Avatar
If I recall, the torque converter bolts should all be 12mm. The best way to remove/install them, is to remove the alternator, and use a long extension back under the intake manifold to the head of the bolt.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-20-2009, 07:55 PM
newkid17's Avatar
yea they are all 12mm but what i have are all different legnths...???and i didnt mean header bolts i ment exhaust bolts....whoops way off....
Old 01-20-2009, 09:22 PM
<<yea they are all 12mm but what i have are all different legnths...???and i didnt mean header bolts i ment exhaust bolts....whoops way off....>>
the 12mm bolts should all be the same length. there not long at all, about an inch and a half at most. do you mean the exhaust bolts that go into the head or the ones that connect the different sectons of exhaust?
Old 01-20-2009, 09:36 PM
You likely mean the header studs that hold together the head pipes and the exhaust manifolds. They are VERY hard to drill out but this might be your best bet unless you have been extracting broken studs in your free time for the past 10 years and are handy with a heat wrench.
The t/c bolts are all 8x1.25 bolts that are equal length. They also have uniqe heads that are shorter than most for clearance reasons. Get the right bolts.
Old 01-21-2009, 09:33 AM
paulmeisterpk's Avatar
paulmeisterpk paulmeisterpk is offline
Sconnie
Send a message via MSN to paulmeisterpk
I had to drill mine too. It was a major PITA, but I really didn't see any alternatives. Took me a couple of hours to do it, cause the studs are really really hard.
I agree with Tom for the TC bolts. Get the right ones.
Old 01-21-2009, 01:14 PM
newkid17's Avatar
can i just go down to the hardware store and buy some 8 1.25 bolts?
Old 01-21-2009, 01:26 PM
newkid17's Avatar
i dont know if anyone can tell but is any of these the T/C bolts?
Old 01-21-2009, 01:56 PM
None of them are
tom
Old 01-21-2009, 02:10 PM
newkid17's Avatar
the one on the right is? in this picture im thinking that is one...i took the bolts out of the T/C and these are the 4 that were in there..
P.S i didnt put those 4 bolts in there to begin with
Old 01-21-2009, 02:42 PM
The one on the right is the correct bolt.
Old 01-21-2009, 07:31 PM
Just get new TC bolts from the dealership-it should only be around $5 for all 4
Old 01-25-2009, 09:07 AM
newkid17's Avatar
thanks guys, i got new T/C bolts and they worked great... i also drilled out my exhaust bolts lastnight wasent to hard to be honest got it done in about an hour!..
thanks, bobby
