Old 02-22-2009, 03:52 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
Re: Resealing the motor
Originally Posted by alia176 View Post
Nice job dude! Forgive my ignorance, what's the advantage with using the WRX mounts vs SVX mounts?
Thanks.
The SVX mounts cost around $200 each, while the WRX mounts are more like $60 each. Plus the WRX mounts are stiffer, stronger, last longer, and are not filled with oil.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 02-22-2009, 03:55 PM
sperry's Avatar
Originally Posted by michael View Post
Grand Total $$$ ???? Minus Knock Sensor,Valve Cover Gaskets & spark plugs
So, total cost of the main seals and cam seals/plugs? I don't remember specifically, but each seal is <$10, so maybe $50?
Old 03-09-2009, 12:43 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
So this thread is a little bit old, but I was wondering what exactly you used as a cleaner and brushes to get the engine that clean. I'm getting ready to pull/reseal mine next week and I would like to get it as clean as possible.
Also, how did you get to everything that was under the intake manifold?
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 03-09-2009, 02:14 PM
sperry's Avatar
I used Gunk engine cleaner and Oil Eater, and used my pressure washer and a set of detailing brushes (nylon, brass, and steel).
To get under the intake manifold, I basically just soaked it down with Gunk and let it sit a while. Then with the motor tilted at 90 deg on the engine stand and with a big old plastic bin under it to collect the run-off, I just hosed it down w/ the pressure washer.
I used a similar technique on the rest of the motor to get into spots like the spark plug access holes, around the oil pan, etc. Most of the hard scrubbing was on parts that came off the motor for cleaning, like the power-steering pump, which got washed in my kitchen sink w/ hot water, dish soap, and a brass brush.
Since I had to do this in my garage (it was Jan and too cold to do it outside) I think I spent more time mopping up the garage after using the pressure washer indoors than I did actually cleaning the motor. My advice would be to park the engine stand in the back-yard in a kiddy pool.
Old 03-09-2009, 05:43 PM
stuartracing stuartracing is offline
Come to find out all my smoking was from residual oil and stuff from a tran.s replacement.... after about 2 weeks it doesn`t smoke anymore....
Old 03-11-2009, 01:52 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
A lot of good tips and tricks in this thread. Great job
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
