Old 01-15-2009, 04:53 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Is this an external trans filter??
Yes, yes it is!
Arrrrrrghhh !!! Now that I have 3,876 confirmations thats it IS INDEED the external transmission filter, maybe we can move this thread to the "Well DUH" section for future reference...
Old 01-15-2009, 08:09 PM
kwren's Avatar
kwren kwren is offline
Yes, yes it is!
Has to be the end of the thread title, Earl
Old 01-15-2009, 09:47 PM
Nah, we are just having a little fun, and not at your expense... No worries
To
Old 01-15-2009, 10:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Oh I wouldnt care if it were at my expense anyways The real fun starts tomorrow when I get my water pump, and subsequent ulcer from doing it lol. Ill have lots of pictures of that im sure, along with a "How-not-to-do" documenting the fun.
Old 01-20-2009, 11:41 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Any home-brew methods of removing the damn left camshaft pulley?? The bolt is in tight and the stupid thing just turns... and I dont want to blow cash on a cam pulley removal tool.
Old 01-20-2009, 12:06 PM
sperry's Avatar
sperry sperry is offline
$1 is just $1, but $2 = nachos
You can use the timing belt to do it, but it'll likely destroy the belt in the process:
Wrap the belt around the timing gear like this (sorry for the crappy 10 second Visio drawing):
Then loop the other end around something on the motor that will anchor the belt. As you wrench on the gear bolt, the belt tightens on itself and prevents the gear from turning. But this will stretch and kink the timing belt, so don't do it if you plan on reusing the belt!!!
This works for the right cam gear too, if you just kink it under the bottom. I also use the same method with the accessory belt for taking off the crank pulley.
Edit: here are some actual pictures of what I'm talking about:
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty
Old 01-20-2009, 08:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Ahhh thanks for the tip lol, I wont tell you what that kind of looks like I will be reusing the belt unfortunately, but im sure I can figure out a way to make use of your suggestion.
Old 01-22-2009, 08:10 PM
liamrh's Avatar
liamrh liamrh is offline
Keith,
Subaru uses a transmission cooler in the stock radiator, so yes those lines are from the front of the trans, through the external filter, through the trans cooler in the radiator, and back to the back of the trans.
Yeah, wtf? Just an external filter for the coolant?
Old 01-22-2009, 08:23 PM
scottsubarus's Avatar
scottsubarus scottsubarus is offline
Scottsubarus
Seems like those recall screw on filters are hard to come by at the dealership. Is there a aftermarket (puralator) filter equivelent avail?
Scott/Omaha
Old 01-22-2009, 08:39 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Not a filter for coolant a filter for the transmission fluid that's just silly.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-22-2009, 08:44 PM
"Quote:
Originally Posted by svxfiles
Keith,
so yes those lines are from the front of the trans, through the external filter, through the trans cooler in the radiator, and back to the back of the trans. "
to both warm and cool the transmission fluid in the stock combination engine coolant radiator and transmission warmer/cooler,
so yes those lines are from the front of the transmission, through the external transmission filter,
(not a spin on filter, but one made like a fuel filter, with tubes in and out, and according to Subaru never needing replacement.)
then the fluid travels through the trans cooler, and back to the transmission.
I hope that this is more clear.
Old 01-22-2009, 10:50 PM
liamrh's Avatar
Yeah, I know what it is for......
Jesus christ guys, it was a sarcastic response to kwren's intial post, lol.
Old 01-23-2009, 09:05 AM
oops.
Old 01-23-2009, 09:28 AM
kwren's Avatar
Please be kind to kwren. He's
(this is all in fun)
Everyone have a great day!!!
Keith
Old 01-23-2009, 12:03 PM
kwren's Avatar
It is connected by two lines going in and out from the bottom of my radiator.... is this the external or something else??
My original response was submitted on the outside chance that the two lines on the external filter were actually connected to the two lines on the radiator... which as you can all see is the actual question.
I was able to install a transmission filter kit and later a transmission cooler on my svx with the help of the kind people on this form.
Again I wanted to make sure that the filter wasn't actually connected in the way that was described in the first sentence in the thread.
We sure got a lot of miles out of it, didn't we!! (so far)
Keith
