Old 01-09-2009, 10:33 PM
redlightningsvx's Avatar
Collision Refinishing Tech
No Ignition,floor, and dome light
Well stupid me accidentally touched to hot wires together for the floor light and now the ignition light, floor lights, and the dome light don't work. I checked the fuses and they are good. What i'm wondering is isn't their a module for those dimming lights like when you open and close the door? Could this be bad or something else?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-10-2009, 10:08 AM
Re: No Ignition,floor, and dome light
bump.....................
Seth
Past subies:
Other toys:
Old 01-11-2009, 07:32 AM
.........anybody?
Seth
Past subies:
Other toys:
Old 01-11-2009, 08:42 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Best guess:
A quick look at the wiring diagram says that if your fuses are good (double check #25, as these all source from there), assuming that the wiring is all still intact, either all those bulbs are shot or you've damaged the output of the time control unit.
Old 01-11-2009, 01:16 PM
Well the ignition and floor light are LED's and the diode wasn't burnt out as well as the fuse. The dome light works but you have to press the button now instead of it coming on when the door is open. Basically every light works but the igntion and floor light and eveything doesn't dim out like it should. Also thier's no power to the ignition and floor lights as well.
Seth
Past subies:
Other toys:
Old 01-11-2009, 02:12 PM
LetItSnow's Avatar
Sounds like time to diagnose the time control unit...
Old 01-11-2009, 02:52 PM
Green1995SVX's Avatar
I agree. I had a similar problem with my 95. It was the time control unit.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-11-2009, 04:06 PM
I think we have a spare time control unit if you need another. keep us posted.
Old 01-11-2009, 04:21 PM
Another thought-
When my time control unit went bad, it was caused by a short in the main harness going from the interior of the car to the fuse box under the hood. It looks like my tire kicked up something sharp which sliced through the fender liner and into the harness. You may want to inspect this area for damage.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 01-11-2009, 06:07 PM
I actually just recently replaced both front fender liners with new oem ones about 2 weeks ago and didn't see anything out of the ordinary. I'll break out the multi meter tommorrow at work and post what I find out. Thanks Mike i'll let you know.
Seth
Past subies:
Other toys:
Old 01-12-2009, 04:27 PM
The Time WARP control module is definatly dead. Mike do you guys have one at the shop?
Seth
Past subies:
Other toys:
