Old 01-09-2009, 11:51 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Re: My possessed car - video
Originally Posted by bheinen74 View Post
get a mm tester and check the battery voltage. maybe the battery is no good, maybe the alternator is not producing 13.8 volts or higher.
its one or the other, or a bad battery connection.
Battery to alternator continuity is good, but I didn't test the voltage the alternator is putting out.. not sure how. Just put on lead on the battery terminal and one on the alternator?
Brian
redlightningsvx's Avatar
Collision Refinishing Tech
Well my guess is that Subaru means the alternator belt.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-10-2009, 12:30 AM
Ricochet's Avatar
I brought some ham.
Oh, I don't know.. it's tight and the pulley is spinning
Brian
Old 01-10-2009, 02:58 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Brian, its pretty easy to check alternator output volts, just use your multimeter between the positive and negative battery terminals while the cars running. Check for volts at idle and revving at around 2000 RPM. Normal voltage is between 13 to 14.75 volts for a good charging system. Any higher and you have problems.... any lower and its not charging at all.
Old 01-10-2009, 08:35 AM
Ricochet's Avatar
I brought some ham.
Voltage of the battery while idling is 11.5
Voltage of Alternator while idling is about 11.8.
So by what you're saying, I bought a bunk alternator?
Brian
Old 01-10-2009, 02:59 PM
Ricochet's Avatar
I brought some ham.
Bought a brand new alternator and it's spitting out 14V, and the lights aren't all flickery anymore. Guess I did buy a busted one earlier.
Brian
Old 01-10-2009, 04:25 PM
I'm very happy to hear that you fixed it. Good luck with a the sale, hope you don't miss it too much.
Old 01-10-2009, 07:40 PM
Happens more often than you would like to think...especially with rebuilt
Old 01-12-2009, 06:43 PM
Glad it's fixed....)
Old 01-12-2009, 07:47 PM
svxash's Avatar
svxash svxash is offline
Even though it's tight and spinning it still might too loose to be charging properly. With my friends car the shop told him he needed a new alternator so he had me look at it first and the belt felt tight but I could pull on it quickly and the belt would move without the alternator pully turning. His volts were around 11.9 and after tightening the belt they came up to around 14.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
