Old 01-07-2009, 09:22 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Power Steering Leak From Cap
Like the title says, after driving for a while I find power steering fluid over the top of the reservoir and I am assuming it is coming from the cap. I find the cap to be a little loose as well. My questions are:
A) does this seem like a reasonable cause?
B) could it simply be that I have too much power steering fluid (the previous owner had over filled it), meaning would I still need a new cap if the level weren't high?
Cheers!
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 01-07-2009, 09:26 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Power Steering Leak From Cap
sounds like its over filled and make sure it has transmission fluid in it and not power steering fluid.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-07-2009, 09:28 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
If the cap is a little loose, it may be missing the gasket or the gasket may be torn. Still shouldnt lose fluid since its a closed system..... did someone mix power steering fluid with the ATF that was in there maybe?? Mixed fluids of different viscosity tend to foam up....
Old 01-07-2009, 09:35 PM
taylorbr's Avatar
Thanks for the ideas - while the engine was warm I popped the cap off and it was very full...of something that is definately not red . And the cap is missing a gasket (I wasn't sure if one was supposed to be there and I didn't think of pulling the one off the Leg, doh).
'94 SVX LSi
Old 01-08-2009, 10:53 AM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
After warming up the car open the cap and check if the fluid is foaming. If it is the o-ring under the reservoir probably has to be replaced.
http://www.subaru-svx.net/photos/user.php?How-To|14284
