Old 01-02-2009, 05:22 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Temp Gauge Stuck
My temp gauge will go up to the halfway point and then doesn't go any further. I've blown a coolant hose, lost all the coolant, had the engine start smoking and it still didn't go past that middle point. (That's how I discovered this lol.) Anything I could try that doesn't require me to see a mechanic?
Old 01-02-2009, 05:58 PM
Re: Temp Gauge Stuck
I thought the same about mine...until I stuffed the bumper vents with snow using the car as a plow and watched the gauge shoot for the moon.
Old 01-02-2009, 06:09 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
This is fairly common in the older resistance type gauges. they develop a magnetic "memory" at the spot where they spend the most time.... which is usually at the regular operating temp spot. If you notice, a lot of newer cars will max out all of the gauges when you first start it to prevent this phenomenon from occuring. One thing you can do is max it out yourself..... you can disconnect the temp SENDER connector (single wire, NOT the two wire sensor) and just ground the lead ..... it should make your gauge hit maximum value. Just do this a few times (but dont hold it to ground for more than a second or two) and make sure the needle jumps to max. This should help restore the function of the gauge.
Old 01-02-2009, 06:18 PM
michael's Avatar
michael michael is offline
What Potholes ???
I'll quess some sort of air pocket in the crossover pipe.
Wanted: Steering Wheel
Old 01-02-2009, 06:24 PM
michael's Avatar
What Potholes ???
Sorry double post
Old 01-02-2009, 07:25 PM
IceBlade's Avatar
Thank you I will try this
