Old 12-25-2008, 02:20 PM
intellibomb's Avatar
intellibomb intellibomb is offline
engine removal with 2002 wrx tranny... cannot separate tranny/engine???
as the title says, i am stuck and it sucks.
i have the engine completely unhooked, all mating bolts removed, etc.
it is hanging by the cherry picker. i have the tranny jacked up with a tranny jack.
the gap between the motor and tranny in 1" all around... the motor is wiggleing and feels like it will go....
WTF?
4 hours of shimmy, pry, pull, adjust, yank, cry, jam, and frustrations.
the clutch seems to be holding it. is there a trick with WRX clutches?
the new clutch, upon examination, holds the throwout bearing in place with a "click" and i think that is what is holding me up. my question:
how the **** do i get it unhooked?
i took off the starter, the slave cylinder, and everything i can think of short of pulling the tranny too.
please help.
thanks! a MILLION!
Old 12-25-2008, 02:32 PM
Re: engine removal with 2002 wrx tranny... cannot separate tranny/engine???
There is a rod that gets pulled out of the transmission right next to where the starter is... There is usually a 10mm or 14mm allen plug that holds the rod in. Take the plug out of the transmission and use a spare 6x1.0mm bolt to thread into the clutch rod and pull it out. Then you can pull the clutch fork up and out of the release bearing.
Old 12-25-2008, 02:41 PM
ahha.... the rod that holds the fork?
i should have known
well, THANKS A MILLION!
i will let you know when i am done...
i just blew my old engine on my birthday so i got a japanese import engine... new wrx clutch and the All We'll Drive engine mounts (isnt that your company?)....
CANNOT WAIT TO LET THE BEAST LOOSE!
one more Q: anything particular to be done on the JDM to make it fit in the USDM car?
thanks again
Old 12-25-2008, 02:44 PM
i should have known
thanks again
Nope... Should be a drop in
Old 12-25-2008, 02:45 PM
right-0
thanks again.
i will post (hopefully today [merry x-mas]) when the job is done....
THANKS!
