Old 12-23-2008, 03:31 PM
Bshade's Avatar
Bshade Bshade is offline
Send a message via AIM to Bshade
Help pulling and ABS code
I have an ABS light on. I know it is one of the wheel sensors as It only lights up once the car moves. Where do I and how do I pull the code for it to find out the wheel in question? Thanks in advance for any help.
Brad the Superlative!
1988 Firebird Trans AM, 1987 BMW 325is,
1978 Dodge RamCharger, 1989 Chrysler Conquest,(2)
1988 Merkur XR4TI 1973 Super beetle Baja Bug
2006 Chrysler 300C SRT8 1996 Buell S1 Lightning
1998 Subaru Forester 1993 Chevy K2500
Old 12-23-2008, 07:37 PM
oldss72 oldss72 is offline
Re: Help pulling and ABS code
if you put the passenger seat all the way forward, there will be a small cutout flap on the door track side. lift this and there will be a small light which will flash the code number after you have driven for a bit. Just check it after a short drive, and it will flash the number of the code.
Old 12-24-2008, 12:03 AM
AUSVX AUSVX is offline
Registered Loser
Flashes
1 -Broken or shorted solenoid valve circuit(s) in hydraulic unit left front
2 -Broken or shorted solenoid valve circuit(s) in hydraulic unit right front
3 -Broken or shorted solenoid valve circuit(s) in hydraulic unit right rear
4 -Broken or shorted solenoid valve circuit(s) in hydraulic unit left rear
5 -Faulty wheel ABS sensor left front
6 -Faulty wheel ABS sensor right front
7 -Faulty wheel ABS sensor right rear
8 -Faulty wheel ABS sensor left rear
9 -faulty motor and/or motor relay or broken or shorted harness circuit
10 -faulty valve relay
16 -fault in ABS control unit
Old 12-24-2008, 02:29 AM
Bshade's Avatar
That is so funny! I have the carpet out of the car as the fuel line is leaking into the cab where it enter so tonight I am driving and I see this red flashing coming from the TCU. I was going to ask if I can remove it but I guess I need it. I noticed it did not always flash it mostly did it when I would spin the tires. As we just had a huge ice storm and all the roads are like an ice scatting rink.
Thanks so much from both of you I will now know what that light is and be able to tell the ABS problem. I knew this was a great forum. I love Cult Cars!
Old 12-24-2008, 06:51 AM
What you're seeing is not the TCU. It's up under the dash to the left of the driver's left knee attached to the ECU and has no lights.. The POWER light on the dash flashes when there's a transmission issue. The ABS diagnostic light is what you see under the passenger seat, mine unfortunately is burnt out.
Old 12-26-2008, 05:03 PM
Bshade's Avatar
Ok I got one flash so is this solenoid valve on the ABS unit under the hood then? I am guessing that is where t would be. I am thinking checking the wiring will be the best bet. I just came back and also got 10 and they sound like similar problems. Any suggestions where to start. And could I keep getting different ones each time if there is more than one problem.
