Old 12-21-2008, 12:48 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Question THUMP when slowing to a stop
Almost every time I stop at a light, as im nearing a full stop, I hear a slight thud and kind of feel it in the floorboards. Theres nothing in the trunk or anything that could be rolling around..... almost seems like the transmissions doing it shifting back into first. Has anyone had this symptom in their transmission? The tranny shifts just fine and I have no other issues with it.....
Old 12-21-2008, 02:13 PM
Old Fogey
Re: THUMP when slowing to a stop
Any similar symptoms shifting into Reverse or into D while stopped? Worn/shot trans mount reacting to downshift as your speed slows?
Glenn
Old 12-21-2008, 03:54 PM
Check to see if you are missing any bolts on your cross members.
I get a thud at low speeds that I can feel in the brake pedal sometimes but I just wrote that off as bad ball joints that I recently removed/unremoved that are flopping around.
Old 12-21-2008, 04:25 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
I'm going to guess that these are his ball joints. Any rubber left on them?
Old 12-21-2008, 08:25 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Does the thump occur about 5 seconds after the complete stop? I had that issue in my first tranny when the transfer clutch was acting up.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-22-2008, 09:23 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Its just before coming to a full stop. Ball joints eh? Yeah ill have to check those, hadnt thought of that. Thats way better than a trans problem.
Old 12-22-2008, 09:47 AM
I have the same problem, no one has been able to properly diagnosis it. I've pretty much just learned to live with it
Old 12-22-2008, 01:40 PM
kwren's Avatar
kwren kwren is offline
Ball joints have rubber on them
Maybe referring to the grease seals?
I wouldn't guess rubber but I might check the cv shafts.
Old 12-22-2008, 03:52 PM
Maxo's Avatar
Maxo Maxo is offline
Do you still get the sound if you slip transmission into N and coast to a full stop? If so I think you could probably eliminate you tranny as a possible cause.
Old 12-22-2008, 08:08 PM
I took it out of teh bag just so I could show you.
In the case of my car, I removed the ball joints for whatever reason, probably to remove the axles, and the black thingy was completely crushed on both units. I didn't have the new ones at the time so I reinstalled them but they did not go in quite the same way they came out so there was a little slack, causing a clunk-clunk sound whenever I exit my driveway over the drainage channel.
I would venture to say it's possible this slack could open by itself in the right conditions.
I don't get any sound or feedback on flat roads, so... don't rule out your tranny just yet.
Old 12-22-2008, 08:55 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Also check the rear differential bushings.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
