Old 12-15-2008, 07:35 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Duty Solenoid A
I've been getting a flashing power light on startup, so I checked this evening and it is coming back as Solenoid A. If I remember correctly, this controls front/rear power split.
Is there anything else that might be causing this indication other than a bad Solenoid A? Are there procedures anywhere for replacing this? Recommendations?
Thanks!
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 12-15-2008, 07:40 PM
Re: Duty Solenoid A
Duty C solenoid/transfer valve controls the amount of transfer to the rear wheels.
Old 12-15-2008, 07:45 PM
Re: Duty Solenoid A
Duty solenoid A is your line pressure control solenoid... Often the circuit is disrupted by a bad dropping resistor. Check the resistance on the resistor next to the battery and get back to us
Old 12-15-2008, 08:50 PM
taylorbr's Avatar
Re: Duty Solenoid A
Well my multimeter took a dump a few weeks ago testing a hot wire fence, so I'll have to check tomorrow.
That does make sense, the guy I bought it from found an AT leak and recently replaced some lines...
'94 SVX LSi
Old 12-15-2008, 09:26 PM
Re: Duty Solenoid A
By line pressure it is meant the actual pressure of the fluid in the transmission, not the external cooler lines
Old 12-16-2008, 08:35 PM
taylorbr's Avatar
Re: Duty Solenoid A
OK, I checked my resistor and it's definitely dead. So I checked the dropping resistor in my Leg and it's ~12 Ohm. I put the resistor from the Leg into the SVX - it gave me trouble codes on the first engine start, but every start after that was code free.
Thanks for the help, glad I didn't buy a new solenoid!
'94 SVX LSi
Old 12-16-2008, 09:22 PM
Re: Duty Solenoid A
glad to hear it was the simple fix!!
