Old 11-27-2008, 08:23 PM
richs1000's Avatar
richs1000 richs1000 is offline
Head Gasket Failure
Im just curious. How many people here have had a head gasket failure?
Old 11-27-2008, 08:29 PM
Re: Head Gasket Failure
me. It was an external leak, between the oil pan and exhaust manifold.
Old 11-28-2008, 10:41 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Me also in my 96 polo, svxfiles did a great job. Runs strong now.
1995 POLO LSI 76K MILES SOLD
Old 11-29-2008, 05:10 PM
Francis Francis is offline
me. on my first svx. my car has been stolen and the guys just beat the crap out of it resulted on a blown hg . i have brought it to the garage , they changed all hg...cost me 2000$ it ended up 2 weeks after with a blown engine...he told me he wasnt responsible because it was block failure and it did not do nothing to pistons...i couldnt get my money back i am sure he ****ed up my car. that made me so pissed off about this car so much money for nothing ....finally i bought a second svx . .
after doing the hg job the oil lvl light was coming up when the engine was reeving at 500 1000 rpm. i guess that didnt help . he did change the oil pump i think he missed something. the engine compression got into the rad wich made the radiator crack ....all the oil and coolant spilled everywhere in the engine bay in about 2 seconds...you should have seen that a white smoking bomb going at 140 kms
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 11-30-2008, 12:26 AM
No problems with mine, but what are thoughts on changing them as preventative maintenance? I would figure it's much more convenient to spend a bunch of time doing it right when you've got the time, than to get stuck with it happening at the worst possible moment.
Old 11-30-2008, 12:38 AM
In order to do the head gaskets you have to pull the motor- Don't even think there are any tricks around this. Plus it doesn't seem too common for HG. Just worry about it if and when it happens i'd say.
Old 11-30-2008, 12:41 AM
Oh I have no illusions about how much work it is, but the car is going to be laid up for a good chunk of next summer while I'm swapping the trans, so that would probably be as good a time as any.
Old 11-30-2008, 12:50 AM
If so you should probably go ahead and get the full gasket reseal kit. It includes all HG, Valve cover gaskets and the 20 washer gaskets for the bolts, Crank and rear main seals etc... its about $240 plus shipping on subaruparts.com.
By doing that you can ensure yourself a leak free and cleaner engine compartment
Old 11-30-2008, 12:54 AM
Already did that. Valve covers, cam plugs/seals, front main, new oil pan, plugs, T-belt...all done this summer, so I've got all the gaskets sitting on a shelf right now.
Old 11-30-2008, 12:58 AM
Well then go right ahead. It sure won't do any harm doing the head gaskets except you might need to get new Head bolts as its not wise to reuse old ones because of all the stress on them. And make sure if you do, to tighten the head bolts correctly to specs to prevent any serious problems(warped heads)
Old 11-30-2008, 10:37 AM
svxpert svxpert is offline
<<you might need to get new Head bolts as its not wise to reuse old ones because of all the stress on them.>>
thats not true. only use new headbolts of you know or suspect they were over torqued. otherwise, i've reused hundreds of headbolts without any problems in Subarus.
Old 11-30-2008, 11:27 AM
I am not aware of any large number of blown head gaskets with these engines, so would not worry about it until there is a problem. There are many that have 250,000+ miles on them without hg problems.
Old 11-30-2008, 11:48 AM
apocalixto's Avatar
apocalixto apocalixto is offline
do da stanky leggggg!
Send a message via AIM to apocalixto
my head gaskets just blew last week. i have 190000 on mine. i had been having the head gasket problem for some time. my temp would go up and down the whole time i was driving. coolant was mixing into the oil. oil was leaking. etc. etc. etc.
at the end of my head gaskets life i just overheated badly, smoke started billowing out of my hood scoop. it was bad. haha. but it is in the shop now. new head gaskets, head studs, intake manifold gasket, exhaust gasket, valve cover gasket, etc.
My SVX
94 Bordeaux Pearl LS
MB Quart components and 6x9s, Autotek "Mean Machine" Amplifier, Pioneer D3 Touch Screen Nav/DVD/CD/iPod, 4 10" PowerBass 2XL Subs, Powerbass XA-3000D Monoblock Amp
Flowmaster exhaust, MP 6000K HID w/ clear lenses and '97 style grille, Carbon Fiber Hood w/ scoop (recently painted), 17" Sport Max rims (gunmetal w/ chrome lip), Ground Control Coilovers, Motorsport Crank Pulley, and Green Filter, ARP head studs, GroupN Engine mounts
4.44 AWD swap w/ Quick Change
Old 11-30-2008, 12:57 PM
immortal_suby's Avatar
Thread Killah
Mine went on my old motor somewhere over 200k.
Locker Link
2015 BRZ Limited 6MT
Old 12-01-2008, 03:41 PM
richs1000's Avatar
Today i noitced i had green crap laying by my throttle plates and moisture in the crankcase vent hoses. any thoughts?
