Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 10-27-2008, 09:58 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: New Car and New Garage
Very nice garage and finally recognition that the SVX is not the ideal race car. The new car should be a real hoot to drive. Your garage is considerably bigger and more finished than mine, but I still love the car(s) in it.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 10-27-2008, 07:33 PM
shotgunslade's Avatar
Thank you, Lee, for the nice words about the garage. It was a lot of fun and really gratifying. I was the architect, structural engineer, mechanical engineer and landscape architect for the project. But, I can't give enough praise to my contractor, who added a lot of creativity to solving coordination issues, developing the patterns for the pavers on the patio and the parking court. He also added a lot of detailing on the finish trim that really added to the look.
As far as retiring the Subaru from track work, it's not because it was unsuited for that role. In fact, it was remarkably quick. (14.9 quarter) Evidence below, a weekend of very evenly matched dicing with a 1992 964 C2 Porsche (Note how he has more body lean than I do).
I was really beginning to learn a lot of the subtleties of the car on the track. Initially, I was guilty of over-driving: Turn-in a little slow, then hammer down well before the apex, power understeering (even with the rear tires also drifting) all the way through the corner, and it would rarely turn on you (did spin a couple of times this way). It was much faster (because of avoided power-on understeer) if I carried a little more speed through to the apex of the turn, apexed a little later, then put the hammer down with the wheels a little straighter. Driven well, the car can be very fast, and it is very stable and very forgiving.
Granted the car is heavy, but with my mods, it has good power. The 5 speed and suspension upgrades make it a very different car. I ran well with a lot of decent cars: stock E36 M3's; late model Preludes; pre 2004 WRX's, etc. I can't really fault it as a beginner track car.
The reasons I'm retiring it are straightforward. The car has over 100,000 miles on it. I'm worried about driving it 5 hours to Watkins Glen, then beating the sh!t out of it for a weekend, then counting on it to get me home. I have driven it home wounded, and I have driven a rental car home. Neither is fun. Also, it has the really bad overheating problem, which I've never been able to overcome even with the aluminum radiator. I could trailer it (assuming I fixed the overheating), but it's heavy (3400 lbs with the 5-speed), so I'd need to buy a Peterbilt to tow it. I know, an F150 would do it in a heartbeat, but in my wife's mind, that is the same thing as a Peterbilt. So I want to tow, so as not to be at the mercy of the track gods for my ride home, and I want to tow with nothing larger than my Subaru Outback. That says I'm not towing the SVX.
If I can fix the overheating problem, I could see trying it at Autocross. or maybe taking it down to NJ Motorsports Park ( 1 1/2 hours away). But prudence says don't rely on a 100,000 mile car to get you home after a grueling track weekend.
Old 11-03-2008, 12:03 PM
wawazat??'s Avatar
Yeah, I'm still around
Hi Dan! The car and the garage are beautiful. Nicely done
I was going to ask you your thoughts on the SVX as a track-toy but then read your last post. Thanks Young Tom finished my car recently and I have all these ideas swimming in my head about next year!
Todd
Down to none
Old 11-04-2008, 05:23 AM
Todd:
What mods did you have Tom make? I assume 5 speed. I know you alreayd had Koni's and Ground Control. I think you will find the SVX a really fun track toy. I hopoe you avoid the overheating problem.
A few words of wisdom:
trailbraking - carefully done, helps the car rotate. On most turns, you should be braking as you head into the apex, instead of accelerating. That also helps you get front end bite and better turn in. That also helps you carry more speed into the corner without excessive understeer.
Full accelerator as you begin to let the car run out after the apex. Full power on with a lot of steering cranked in just gives you a lot of understeer.. In some really tight corners, I come in trail braking, let up on the brakes, then crank the wheel hard over to get my turning done, then full accelerator as I loosen my grip on the wheel and let it straighten out naturally.
At first, I had a tendency to get on the accelerator too early. I woulfd be on full power well before the apex. That was before I really internalized the friction circle. If you are turning and accelerating fully, you will be in a 4 wheel drift, but, it will be unstable. Sometimes the rear end will begin to come around and there is nothing you can do about it, except countersteer, assuming you have room on the pavement. If you've already tracked out pretty far, you may be cutting some grass.
The better line is to carry more speed into the corner, gently braking into the apex, then get down hard on the accelerator at a point where you canbegin to let it track out. Once you get that down, it flies. From this, you can see that the car likes a very late apex. Get your turning done early, under trail-braking, then your acceleration run out of the corner will be straighter. Believe it or not, your exit speed will be higher, because you carried more speed into the corner and had less scrub coming out.
The rain is wonderful. All of a sudden, you are the fastest car on the track.
I haven't been on the track in 4 months, I guess you can tell. It's a real hunger.
Old 11-04-2008, 06:32 AM
wawazat??'s Avatar
Dan,
I have two SVXen. Tom converted my '92 LS-L with 147k miles to a manual. It has only KVR drilled front rotors and their brake pads. Otherwise it is stock down to the original struts and, right now, 13 year old RE-95 tires My '95 has the suspension, brake, seats, harnesses, too many sets of wheels and tires and Stage 1v.5 chip.
I'm trying to decide how much I want to destroy the '92's street manners/capabilities by gutting and prepping the car. Both SVXen are extra cars for us and I have my own Peterbilt tow rig I really want to do some track days next year so the '92 makes the most sense to mess around with for these events (higher mileage, lower value). I can swap the suspension (or get off my duff and finish the double adjustable suspension) and the seats/harnesses to that car. We'll see...
Todd
Down to none
Old 11-04-2008, 10:44 AM
The 92 sounds good. You will absolutely want suspension work. OT's two mods are good. I don't need to sell you on the GC/Koni fix. I have 335 lbs/in front nad 285 lbs/in rear, which seems to be stiff enough for track work, and yet not unreasonable for the street. Note my lean level in the picture above vs that of the 964. I have had great results with AXXIS Ultimate brake pads on the front. They odn't fade and last a pretty long time (4 to 6 track days) I also really love my Bridgestone RE01-R's. Great for rain or dry. They don't talk to you as much as the BFG G-Forces I had previously, but they have better overall grip and talk enough to let you know what is going on.
Have fun
Old 11-08-2008, 02:02 AM
subbieatnz's Avatar
Such an awesum looking garage. I so want an big one like that. all i have is the lawn and concret pad to work on
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 11-09-2008, 07:45 PM
Re: New Car IT'S HERE
It's here. My daughter and I preparing for our first drive. It didn't get here until about 3:30pm, so only had time for a couples of rides around the block. Next weekend. The provisions for NJ registration detract a bit. The heat shield for the exhaust is downright ugly, and the windshield isn't the most elegant, but...
Old 11-11-2008, 07:40 PM
Dan,
Good Luck. The car looks great! Enjoy it.
Old 11-11-2008, 07:49 PM
Wikedjuggalo's Avatar
Rebuilding
Damn I must say I am jealous =D.
Very nice
Old 11-12-2008, 08:49 AM
Thank you all. I will report on track days next spring. Who knows, if I could cure the SVX overheating problem, it could still go out on the track, especially if the forecast is for rain.
Old 12-23-2008, 02:47 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
I love your garage
Marisa
Old 12-23-2008, 03:13 PM
RSVX RSVX is offline
Network Design Administrator
I think the EZ Pass unit on your front tag while racing is awesome.
I can see it now, Track Fees paid via EZ Pass.
Life is a game. Play to win.
Old 12-23-2008, 03:27 PM
nice everything. btw my 92 SVX lsl is rocking those same wheels, courtesy of the previous owner, and its same color, so that car is a twin.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 12-24-2008, 10:20 AM
Looks like the SVX may be back on the track again by the end of this year. I was thinking about selling it and buying buying a Cayman S, (mainly to get access to the good track days that the Porsche Club has), but I couldn't do it. So, it looks like a total refurb, built NA engine, refurbed and upgraded suspension, ulimately, body detailing and a good quality respray, interior redo and maybe seat upgrade, an electric water pump, and a radiator cap that really seals . Plus whatever else seems like a good idea.
Addiction is a terrible burden.
