Old 06-25-2002, 01:14 AM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
Driveline repairs almost finished
Okay, I'm just posting this to see what people think of my situation.
As some of you may remember my U-joints went out in my driveline awhile back. I've since taken out the entire driveline and am in the process of converting the "staked" or "mashed" in U-joints with a sort-of conversion to clips. (basically the clips are on the inside of the yoke instead of the outside) My slip yoke was completley thrashed so I got a new one from the local driveline specialists but unfortunatley it takes a different size U-joint then the conversion ones I bought from Rockford Driveline. So they are going to cut off and weld on a corresponding size yoke to the driveshaft side to match the new joint on the new size slip yoke. All for about $180. Not bad considering the local repair shop I used to go to wanted to charge $550 for a new driveline from the local Suby dealership. So now tomrrow after work I am going to pick up my driveline and put it back in. Then I'm going to go to the local Checker Auto and buy a CV boot kit. *sigh* I'm just hoping that if I keep working on it during the summer it will eventually get fixed enough to start "upgrading" the car. (like exhaust n' such) Also, after I fixed to two side garnish problems caused by the previous owner's need to epoxy the car together (thanks for the diagrams again Randy) I noticed the plastic top part to the radiator had some pretty green stuff leaking out of it. Will the fun never cease? Oh well, signing off for now...
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
