Old 09-25-2008, 07:29 AM
subiedo subiedo is offline
2007 WRX 5 speed ?
Just a quick question that I'm sure someone knows the answer to. I've wanted to swap in a 5 speed for some time & found a 2007 WRX 5 speed & rear end with 7k (roll-over). Is the 07 5 speed compatible ??
Thanks
Old 09-25-2008, 07:57 AM
sicksubie's Avatar
Re: 2007 WRX 5 speed ?
Should be.... Nothing changed that I know of...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-25-2008, 08:08 AM
get the rear diff to match. They changed to a 3.70 FD in 06. Not to mention the clutches changed then too so make sure that you get a clutch/flywheel to match the trans
Old 09-25-2008, 08:31 AM
Thanks Tom. I'll check with the seller but does have a rear end with it. Not sure about clutch / pressure plate. If I get this, it will be a bit of a project & will probably require your 5 speed conversion hardware right? Please advise as I'll want to get rolling on it soon. Thanks, Zane
Old 09-25-2008, 08:45 AM
Yes you are going to need a X-member, shifter linkage, driveshaft, pedal assembly, starter, flywheel, clutch, and all associated Hardware. Having the trans is one thing... More times than not, the rest of the hardware will cost more than the trans itself.
