Old 08-31-2008, 05:27 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Ac belt replacement?
I have the new belt on, but I can't get the tension right??? any help will be appreciated
Old 08-31-2008, 07:25 PM
Manarius's Avatar
Manarius Manarius is offline
Re: Ac belt replacement?
Loosen the nut on the tension pulley (the pulley directly below the power steering pump) and then tighten or loosen the tension bolt to adjust the tension. Then tighten the tension pulley nut and you're done.
-Jason
-Obi Wan Kenobi
Old 08-31-2008, 07:36 PM
This is the belt that goes on the Ac compressor, not the alternator belt. But, Thanks for the reply
Old 08-31-2008, 07:54 PM
Loosen the nut and use a long screw driver or long breaker bar to get some leverage on it and once it is as tight as you want, secure it.
Old 09-01-2008, 12:26 AM
Hondasucks's Avatar
Subaru Technician
At the proper tension, you should be able to twist the belt 90 degrees but not much further than that. Don't overtighten the belt or it will break (been there, done that, $18 OEM belt!)
1986 VW Jetta
Old 09-01-2008, 08:15 AM
Manarius's Avatar
Hah. My fault. My brain and fingers were in two different worlds at that point in time.
Earl's instructions are exactly the ones that will work.
-Jason
-Obi Wan Kenobi
Old 09-01-2008, 11:19 AM
Unhappy Re: Ac belt replacement?
So it turns out the reason the original belt broke was because the bearings on the tension pulley were shot!!! So now, I need to replace that bearing, any clues for were to get it,does any one have a diagram?
Thanks for the other replies guys!
Old 09-01-2008, 06:31 PM
Hondasucks's Avatar
Subaru Technician
You can order the bearing (Most likely will come with the pulley as well) from the dealer, or you can take the idler unit off, remove the pulley, knock the bearing out, and go to an industrial supply store and they should be able to order you a bearing.
1986 VW Jetta
Old 09-01-2008, 08:33 PM
I use a 17mm box wrench (unlike the combination wrench shown below), after the two 12mm lock bolts are loosened.
Old 09-02-2008, 05:18 PM
Thank you so much for the great picture and for all the help. I was able to get the bearing out and got a replacement from Napa auto parts for $25 - great deal compared to local Subaru dealer $125
AC is now working again
