Old 08-21-2008, 08:00 AM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
Question Removing rust from disc rotors
Before I bought my girl she'd been pretty much laid up and neglected in favour of a company car that didn't need a new windscreen for six months or so. Here's one of the results:
She comes back from the mechanic tomorrow with her new, improved, no leaks steering and I'd like to get this sorted over the weekend, only I'm not sure on method. WD-40 and scrubbing (wire brush?) comes to mind but don't know if its safe, or if there's a better option.
Is there a 'prescribed' way?
Thanks,
ever-growing sort it out list chickie.
1992 Onyx SVX 184,500kms
Now with new and improved no leak steering!
No plants = no life on earth - so go forth and plant green things!
Old 08-21-2008, 08:10 AM
Francis Francis is offline
Re: Removing rust from disc rotors
buy new ones!! ...i dont know i would say as long as u dont touch inner part "where its shiny" maybe it could make it squeeeeeek if u resurface it
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 08-21-2008, 08:57 AM
plantchick's Avatar
Heya Francis, thanks for the input.
I'm a student, bought my girl three weeks ago and have spent a couple of grand since, getting her sound and happy. I've been told by a mechanic and a suspension/alignment guy that they're fine, pads have ~65%. She sure as heck bought her ABS to the party and stopped me in a hurry when I needed to the other day.
If what I've been told is wrong, then its wrong, But I really can't afford to replace parts that don't need to be.
Tania.
Last edited by plantchick; 08-21-2008 at 09:27 AM. Reason: 'cause my wording was poor and sounded harsh
Old 08-21-2008, 09:23 AM
Old Fogey
If that view is from the rear of the rotor, I say if it ain't broke, don't fix it. Your wd-40 and wire brush idea won't cut it. Brake rotors are more or less "sacrificial" parts, being replaced periodically through the life of the car. Just my $.02.
Glenn
Old 08-21-2008, 10:30 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Leave them alone until you need to replace them and then get ones that are zinc coated.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-22-2008, 07:12 AM
legacyau legacyau is offline
Like the others have said leave them be and replace when needed, they are not readily available as an aftermarket item here i'm yet to find a non genuine replacement. they are available on ebay but freight is the killer and aside from looking s h i t e if its working dont fix it but you could use a wire wheel on a drill to take off the rust from the centre of the hub but stay away from the surface where the pads rub
cam
Old 08-22-2008, 07:25 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
It would be handy if you had access to a blast cabinet. I've stripped the paint and rust off of a set of struts and a pair of exhaust manifolds, and they look so nice afterward that I want to put 'em in the wife's curio cabinet.
She told me "no".
Old 08-22-2008, 08:10 AM
SVX_MY_BABY's Avatar
Just looks like cosmetic surface rust. I you really want to get rid of it you could use elbow grease and coarse sand paper. Even a file if there is a noticeable ridge of rust at the edges. Be sure to keep any debris away from the calipers. You could then use a fine paper on the hub and use a high temp. paint. Don't paint the area where the pads touch. Definitely don't use D-40 on any lubricant on brake rotors.
Old 08-23-2008, 03:45 PM
plantchick's Avatar
Glenn
It is the rear - the front has a little on the top edges of the rotors, but not on the face(?).
I'll add this one to my list of newbie questions.... How does it being the rear vs. the front make a difference?
-Bill
Thanks Bill, does seem like its the way to go, but... darnit!
'cause....
Old 08-23-2008, 03:54 PM
plantchick's Avatar
They do look like s h i t e!
But since its a cosmetic and not a safety issue, I'm just gonna have to deal with it for now and maybe try some of the suggestions once I've sorted more important stuff. Not about to hope they go anytime soon, especially with what you've said about replacements.
Tania.
Old 08-23-2008, 03:59 PM
plantchick's Avatar
She told me "no".
Hey, there's a hidden message in there!
Well, once I went and looked up what a blast cabinet was and did
I want one!
Thanks for the idea. Wondering if maybe somewhere hires them out, or does the work. Not that I'd even think of dismantling brakes at this point, but all things in time....
Thanks LetItSnow,
Tania.
Old 08-23-2008, 04:12 PM
plantchick's Avatar
Very glad I asked about the WD-40 before just doing it!
The rust doesn't look deep, no - some washed off when I started working on cleaning the wheel wells. (another ten passes and they might look respectable).
Another newbie question.... Now that I know it won't be a deterioration problem, it moves down the list of things to do, but if I were to, how would I go about keeping debris from the calipers?
Tania.
Old 08-23-2008, 05:05 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
-Bill
+1 or maybe you can get it painted...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 08-25-2008, 07:22 AM
Tania.
Best to take the rotors off. Leave the calipers on the car. It's not hard, only a few bolts. Other than that I'd say pack a rag around the front & back of the caliper where it meets the rotor then make sure you give the rotor a good spray & wipe with brake cleaner before you rotate it to get to the next spot.
Have a look at a Haynes or Chilton manual. Great for a novice & usually carried by public libraries. Some are generic, most are brand/vehicle specific.
http://catalogue.halifaxpubliclibrar...pect=subtab431
Old 08-26-2008, 06:15 AM
plantchick's Avatar
Thank you very much for this - explanation and link, both. I'd heard about things like it, but hadn't checked them out yet. I downloaded the (US) workshop manual from STIS and it helps a lot, but naturally enough assumes a ton of knowledge I don't have.
The library didn't have anything (smallish regional town) so I ordered something like it from the autoparts shop.
*grin* so what if I end up living off baked beans for a bit.
I've got a great car and she's getting happier by the day.
