Old 08-17-2008, 06:44 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
code 11? crank angle sensor
i just checked my codes today, i check them every once in awhile because my cel is always on because my speedo doesnt work, i check it every month or so to make sure nothing new pops up. well today i checked them and i get code 11. how can i fix this? do i have to buy a new sensor or can it be cleaned etc? and how can i check this part? thanks for any help.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 08-18-2008, 02:17 PM
Elaine Elaine is offline
Re: code 11? crank angle sensor
There are quite a few posts on this topic. Basically if you want to do a quick sanity check remove the connector and measure the resistance of the sensor (around 2.5 Kohm) and the resistance you can see at the two pins of the connector (around 80Kohm if I have a good memory).
For a more advanced test you need an oscilloscope. I can provide all the details, just send me a PM.
Elaine
