Old 09-04-2008, 12:07 PM
sicksubie's Avatar
Re: Car still wont start...
@ 1k rpm idle.....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-04-2008, 12:08 PM
Originally Posted by sicksubie View Post
@ 1k rpm idle.....
Thats a high RPM for that vac. it should be closer to 20... Either way if the AFR is good at idle and through various other conditions it should be OK.
Old 09-04-2008, 12:13 PM
sicksubie's Avatar
I think there could be a leak, but I will be checking in a few minutes when I go back to the garage. I can get you EGT readings then too if you want.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-04-2008, 12:34 PM
yea man that would be cool. I just want to double check the gauge readings
Old 09-04-2008, 12:50 PM
sicksubie's Avatar
Do you know the belt sizes btw???
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-04-2008, 01:07 PM
5060555 if you have my belt set-up... Otherwise I have no idea sorry man
Old 09-04-2008, 01:33 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Bobby,
how are you getting 23 inches of vacuum under load? you should be going positive with the s/c
I'm running 20 inches of vacuum at idle with my in/ex cams (non stock).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-04-2008, 01:35 PM
sicksubie's Avatar
Originally Posted by SVXRide View Post
Bobby,
-Bill
Sorry... That was while moving and letting off the gas but I realized that vacuum should fluctuate with speed and engine rpm
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-04-2008, 01:36 PM
Bobby,
-Bill
called negative load silly
Old 09-04-2008, 01:37 PM
BTW that should also be closer to 25"... My new gauge only reads PSI + and - so our comparisons are not really worth much anymore.
