Old 08-15-2008, 04:18 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Select monitor diagnosis
Well I hooked up a select monitor to my car at work today and ran a full scan on everything. Everything came up perfect except it couldn't find/read my abs? Is this bad, I have never had an ABS light ever show on the gauge before?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-15-2008, 04:41 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Select monitor diagnosis
I don't think the SVX ABS system has the ability to talk to a select monitor. That function of the monitor is probably for newer models.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-15-2008, 04:44 PM
Does the ABS light come on when you start the car?
Old 08-15-2008, 06:08 PM
No it doesn't come on. The cartridge was for 97' and below and it checks all computers for codes which the ABS can show but it wasn't able to communitcate with it.
Seth
Past subies:
Other toys:
Old 08-15-2008, 07:44 PM
If the light does not come on when you start the car, the light is either burnt out or the abs is not good. If you take your car to a stealership and ask for the abs to be checked, they will look for the light to come on when you start it. If it comes on, it is ok.
Old 08-15-2008, 08:17 PM
Hey I work at a Subaru dealership!!!!! I'll get the Master Subie mechanic to take a look at it on Monday.
Seth
Past subies:
Other toys:
Old 08-15-2008, 08:19 PM
Yeah, if the ABS light isn't coming on at all, my guess is that the previous owner disconnected the box and yanked the dash bulb.
Old 08-15-2008, 08:28 PM
Ohh I know what you mean now by the light being on. It comes on with all the other lights and then goes away when started. I thought you meant does it stay on when the car is running. I still don't understand why the select monitor couldn't read it though?
Seth
Past subies:
Other toys:
Old 08-17-2008, 02:18 AM
b3lha's Avatar
Phil & Belha
In the 92 wiring diagrams, the Select Monitor connector is not wired to the ABS computer. There is no way it is ever going to show a code.
Maybe the OBD2 cars are wired differently.
Old 08-17-2008, 09:04 AM
Ok thanks. That make me feel better.
Seth
Past subies:
Other toys:
Old 08-17-2008, 08:42 PM
Hondasucks's Avatar
Subaru Technician
Yeah, you are right, the Select Monitor will not read the ABS codes. Even on some of the newer cars you have to plug a pin into a connector under the dash and count the blinks of the ABS light.
On the SVX you have to look at the light on the ABS module itself, it's on the passenger side, not sure if you have to take the seat out or not, but if your ABS light doesn't come on once the car is moving (You may notice at night, when you first start the car and get moving about 5MPH, a quick "blip" of the headlights, that is the ABS unit running a self test) then your ABS is working normally.
1986 VW Jetta
Old 08-18-2008, 03:33 AM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
Hey, I wondered why my headlights did that the other night! Was going over a speed bump at the time and thought "oh hell, please don't let me have a wiring problem". (knew the ABS was fine 'cause I'd needed it the day before and it came through for me)
Ta Honda.
1992 Onyx SVX 184,500kms
Now with new and improved no leak steering!
No plants = no life on earth - so go forth and plant green things!
Old 08-18-2008, 07:16 AM
SVX_MY_BABY's Avatar
You may also notice a slight pulse of the brakes just after you start the car. That's the the ABS self check too.
Old 08-18-2008, 07:57 PM
Hondasucks's Avatar
Subaru Technician
Yeah, on a side note, the pump that's in the ABS module makes one hell of a water squirter! We had one come in with a bad control unit, and since you can only get the electronics WITH the hydraulic unit we had to replace the whole unit. (They are available to GM as separate pieces, but not to Subaru) So the master tech hooked the motor directly up to 12V and fluid shot halfway across the shop, we're thinking about trying to fab up some sort of uber water cannon, use a Prius auxiliary battery to power it.
1986 VW Jetta
Old 08-21-2008, 09:03 AM
dromano's Avatar
dromano dromano is offline
I just purchased an OBDII code reader for my 04 Silverado. The code reader only displays "P" codes which are for emmisions. I found this site: www.batauto.com they break down the OBDII codes into 4 groups, they show ABS codes in group "C", its codes deal with circuit integrity.
The site has forums broken down by several categories, one is "imports", you might find some ABS info there.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
