Old 09-02-2008, 06:50 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
Re: Sourcing an oil leak, can someone point me in the right direction?
Well the PCV replacement did not fix my problem. Those little divots on the engine are filled back up again. Any other suggestions on a fix? Im getting tired of getting out of my car and smelling burning oil.....
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 09-02-2008, 06:59 PM
A few days ago my car began to fiercely pool oil in this spot. My IRIS valve was supposedly replaced 300 miles ago, completely, so I am assuming I have blown a headgasket towards the top rear right of the engine. I actually lost a few quarts over only 250 miles.
Might want to look at yours.
Nevermind. I'm going to now say they failed to properly fix the leaky manifold. Granted it was almost exactly one year ago, I have only driven the car 300 miles since then. (Though still, my gasket looks like ****, same as ever. I've got my eye on you, head gasket.)
Old 09-07-2008, 11:05 PM
mysvxrocks's Avatar
Who replaced you IRIS valve? And how much did they charge? Thats the piece that is inside the intake correct? looks like a round flat piece of metal that opens and closes?
So I found this pic in Pearlm30's locker and had to steal it lol. Heres where I have oil dripping, at least from what I can see. I get oil on my hand no matter where I touch there, and its dripping farther back as well, but I cant see from where.
D.J. McPhee
Old 09-08-2008, 12:13 PM
Local Shop.
$728 in parts, $360 in labor.
Yes.
I don't know.
My manifold is definitely not leaking from where you pointed out. Quite a mystery.
Old 09-08-2008, 09:29 PM
My only other idea is that it may be the valve cover breathers. On top of each valve cover is a little black plastic box. Each has a large vaccuum line that goes to the underside of the big plastic box part of the intake just behind the throttle body. You may be drawing oil out of the valve covers, into the intake, through the throttle body, and into the manifold and IRIS. Check the inside of the intake tube and the throttle body for oil. If that's what you've got than I'm not sure what the best cure is, other than a catch-can rigged up with those vaccuum lines. The oil can't be coming back up from the cylinders or through a head gasket without making some very serious problems (ie, massive backfires and such, blowing the intake off the car, etc).
Edit: Ref; this thread
Old 09-18-2008, 01:08 AM
kwren's Avatar
kwren kwren is offline
Originally Posted by dromano View Post
To change the PCV valve you will need the correct size crows foot wrench, a universal socket, extension and ratchet. It is located at the rear of the top of the engine, in the middle under the throttle body. It's not the easiest part to change, cause you can't see it. It's all about feel
I just take an alternator bolt out and hinge it up out of the way, then reach under the intake manifold with one hand and remove it after it is loosened with a crows foot. There are some really good magnates that telescope out if you need to fetch something... like your 19 mm crows foot (what is the universal socket for?)
Piece of cake!
Old 09-18-2008, 01:10 AM
kwren's Avatar
Piece of cake!
Old 09-18-2008, 01:12 AM
kwren's Avatar
sorry, don't know how that happened... Maybe should be in bed?
Old 09-18-2008, 10:16 AM
jrobe jrobe is offline
My car has oil pooling in the same spot also. I temporally rerouted the valve cover breather lines into the frame rail and pluged where they connected to the intake duct work. STILL oil is pooling, I'm hoping there is some more oil inside the intake that needs to work it's way out. We will see after time.
Someone told me to check the oil fill tube oring. When I pulled it off I could tell it was leaking there also. I siliconed it and the oil is still pooling on the top of the motor, but one less leak to deal with.
Jrobe
Old 09-18-2008, 05:50 PM
I discovered my leak was caused by a faulty oil pressure switch, located near the alternator. It leaks quite discretely.
