Re: electrical questions after 5spd swap
Tom |
Hello All!
Now, my only problem is the starter. Since I had done the 5mt swap, the car starts bad. I use a Legacy 2.2 starter. When i start the car, i have to push the gas pedal and after 20-30 seconds the car runs good. When the engine is warm, the car starts good. Is the Legacy 2.2 starter too slow for the svx engine? Can i use the svx starter too? (if yes, how would you modify the starter?) Thanks! |
what does the speed sensor do? and you HAVE to use the svx one not a wrx one??
Hi,
speed sensor doesnt work yet. But is it necessary for starting the car, too? Greetings |
If it weren't for the fact that his problem started at the same time as your transmission swap, I'd say that your coolant temp sensor is bad. The hard starting and fans running all the time is exactly what it does when that sensor is bad.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Hi,
but the water temp display works . when engine is warm, the pointer is between warm and cold. Thanks |
There are 2 temp sensors...a 1-wire that runs the gauge, and a 2-wire that runs the ECU......
Okay thanks,
i will check it and replace it if necessary. Greetings |
The radiator fans are reliant upon the speed sensor information. So when the ECU sees there is no sensor hooked up, it will keep the fans on all the time
Tom |
Hi,
ok it must be the speedsensor. I reseted the ECU and started the engine. The fans didnt run. When engine was warm, the fans turned on only for a short time (and everytime when engine became too warm). So i think, the water temp sensor is okay? Now I will check the speedsensor. Greetings and Thanks! |
Hi SVX guys ,
problem isnt solved yet . I installed the speed sensor. fans working great now. When i check ecu error codes, i only get error 12 (the starter switch). so it cant be the temp sensor? I try to describe my problem in detail. When the car is cold, i have to pump the gas pedal 3-5 times, and when i want to start the car i need to press gas pedal to get the car started (if i dont do it, the engine wont get fuel i think). then, after 10 seconds the engine try to start , rpm goes to 700-800 and the engine stops again. then, i try it again , and immediately when the engine goes up to 700 rpm, i press the gas pedal to reach 2000 rpm. after 5 seconds the ecu control the A/F and rpm is normalizing. When the engine is warm, and i want to start the car, i have to press only abit the gas pedal, but the car runs immediately after i turned the starter on. Could it be the fuel pump? When the engine started, the car drives as normal as ever. Is there a fuse for the pump? When i turn ignition on, i cant hear the pump from back of the car. Thanks in advance Greetings |
Indeed it is.. I just did my swap and used his write up.. Every thing is working great!!!! Thanks huck for the help.. only thing left is the drive line extention.. Oh and I got my car electrical figured out from me post on electrical.. It was a grounding problem
#28
I used the N/A Impreza (model of donor car I used) starter and she starts right up every time.. no problems with fan on all the time Either... I would look into the relays as well. Just my opinion. But now that I have read on I see that issue has been fixed lolol. Last edited by Brandon770; 04-12-2009 at 01:17 AM. |
#29
You might check all your vacuum lines. I had kind of the same problem at first when I did my swap and found out that one of the main vacuum lines were disconnected from my intake. It wouldn't stay running all the time and then after I found the vacuum and hooked it all up it purrs like a kitten. Even though I have a sticky lifter now, but that another problem in itself... Gaaaa. Time to flush the motor and put some treatment in it. |
#30
Hi,
thanks! I will check that. I use a 92 Legacy 2,2 starter. When i turn on ignition, i hear the relays in the engine bay. But nothing from the back of car (fuel pump). Greetings |
Thread Tools | |
Display Modes | |
