Old 07-31-2008, 11:48 PM
Exclamation trans hose broke how much oil do i put in ?
how do i make certain ive put enough in?
Old 08-01-2008, 12:26 AM
Re: trans hose broke how much oil do i put in ?
The only way I know for sure is to look at the dip stick. It should be running when you check it. Did you loose all of it, or just have a major leak? Good luck.
Old 08-01-2008, 02:45 AM
lol i knew that much i was just curious about all the air in the lines and how to get it out properly do i just go through the gears with it running not moving or drive n stop drive n stop ? i cant afford to have major problems with it at the moment
Old 08-01-2008, 06:50 AM
It will pump the air out on it's own.
Add some fluid, run the engine in park for 30 seconds, then shift through gears, back to park and check. Repeat as necessary.
Is there anything on the stick? If so, add a quart at a time, if not add 2 quarts at a time until it registers on the stick.
Old 08-01-2008, 07:01 AM
legacyau legacyau is offline
i think from empty they take about 9 litres but like they said check and fill till its right it'll surge on u turns if there isnt enough fluid
regards cam
Old 08-01-2008, 07:05 AM
Also, overfilling is bad, and it's hard to remove just a quart
Old 08-01-2008, 03:58 PM
Thanks guys i put a litre in yesterday and it was just at bottom notch i think . Using different brand atf oils prob not the best idea either ? i have some valvoline type 95LE is that ok to use i dont want to grenade my trans? lol
