Old 08-06-2008, 06:54 PM
SVX ROO SVX ROO is offline
Re: Simultaneous overheating and loss of A/C
There is no evidence of anything nasty like a head gasket. I am not losing water or boiling over. I just run half way up to the red line and the air quits working until I take one of the previous mentioned remedies. Cooler weather the last couple of days has "solved" the problem for now.
Yes, both fans run.
Larry, Prancer is running fine, just needs more exercise.
Ken
Ken
'94 Bordeaux
1984 Ferrari 400i (4.8 liter V-12)
'69 Lotus Elan +2 w/Cosworth BDR
'04 Audi allroad 2.7 TT Black
Old 08-08-2008, 04:15 AM
LarryIII LarryIII is offline
I just sent an e-mail to SVX ROO with a scan of the engine cooling section of the SVX Shop Manual for the '92 models. I thought that I'd upload it here for anyone who wants it.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 08-08-2008, 10:57 AM
kwren's Avatar
kwren kwren is offline
thanks Larry III & The Beautiful Naviguesser!
Good information to have,
Have a great weekend...
Keith
Old 08-08-2008, 05:13 PM
Thanks Larry. I'll read over weekend.
KB
Ken
'94 Bordeaux
Old 08-09-2008, 09:25 PM
apocalixto's Avatar
apocalixto apocalixto is offline
do da stanky leggggg!
Send a message via AIM to apocalixto
this is very funny. I was doing a hill country drive with some of the svxers in san antonio. I started overheating and cooling down almost instantaneously. It would go all the way to hot then just go right back down. I replaced the thermostat thinking that would be the issue. It got me back to dallas with no issue at all, but as soon as I pulled into the city limits, my temp started rising...and as mentioned...the AC would blow HOT HOT HOT air.
I finally drove it around for a while after that with no issue. finally, after driving for 15 minutes one day it started doing it again. I decided that I should go get a new radiator...and went ahead and replaced the whole AC system, because the parts were all showing like they needed to be changed. they were leaking, the expansion valve was clicking, and the compressor was trying to go out.
However, after fixing all of that, it did it again. Only one time though. Mind you, the temp here in dallas when it happened was pushing 110.
Any more ideas?
My SVX
94 Bordeaux Pearl LS
MB Quart components and 6x9s, Autotek "Mean Machine" Amplifier, Pioneer D3 Touch Screen Nav/DVD/CD/iPod, 4 10" PowerBass 2XL Subs, Powerbass XA-3000D Monoblock Amp
Flowmaster exhaust, MP 6000K HID w/ clear lenses and '97 style grille, Carbon Fiber Hood w/ scoop (recently painted), 17" Sport Max rims (gunmetal w/ chrome lip), Ground Control Coilovers, Motorsport Crank Pulley, and Green Filter, ARP head studs, GroupN Engine mounts
4.44 AWD swap w/ Quick Change
Old 08-09-2008, 11:12 PM
kwren's Avatar
are both fans working and are you losing coolant?
Old 08-10-2008, 01:37 PM
apocalixto's Avatar
both fans are working and the coolant isn't leaking...
My SVX
Old 08-10-2008, 07:12 PM
kwren's Avatar
Are you sure that the fans are working at the time that the overheating occurs?
Could be spasmodic... a possibility.
A strange one... But always a logical reason.
Keith
Old 08-17-2008, 12:50 AM
kwren's Avatar
Did you get it worked out??
Thanks,
Keith
Old 08-17-2008, 03:12 AM
drivemusicnow's Avatar
Poor College Racer
Soo. Since I've been through every coolant fix in the world... Here's some SVX knowledge:
A) A/C compresser is shut down by the ECU when the engine temp is hot (not sure the exact temp
B) If you're not loosing coolant, you're getting extra heat in the system somehow. An SVX has a quite exceptional coolant system and can keep a well functioning car at temp with less than 2/3rds of the coolant capacity.
C) It's your headgasket.
Sucks I know, I'm about to replace mine on my SVX, but apparantly it's pretty common on high mileage SVXes. Failure mode is to allow combustion gasses into the cylinder, without any coolant in the exhaust, or oil coolant mixture.
My car started with the same symptoms. Never all the way to red, increasing RPM would decrease temp. It would be once every few months that it acted up. Then once a week. Then every time the car for longer than an hour. Then every time I drove the car for more than a half hour... My problem got significantly worse when I blew that crap plastic endtank up on the radiator and the temp gauge spiked.
One of the reasons I think this problem is hard to diagnose is that you if you pressure test the coolant system cold, it will typically test fine. I even had a "block tester" kit from Napa test negative (tests for exhaust gasses present in the coolant) when this problem was just starting.
Easy way to tell: Completely remove the thermostat, beat on the car, see if it still overheats.
(by the way, all of this is assuming that you can tell if your loosing coolant, know how to properly bleed the coolant system, know how to check if the fans are operating correctly, and all other basics. sometimes its something easy. I replaced every component of my cooling system including the water pump, which looks fairly indestructible, to the radiator hoses..)
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 08-17-2008, 11:35 AM
kwren's Avatar
I think you are right Greg
It's going to be the head gasket
Keith
