Transmission and radiator temps.
Fun With Numbers
I had an SVX on the lift this morning with the thermostat removed to circulate a radiator flush and took these digital readings all within a few minutes, after the car was running for about ten minutes. The dash temperature gauge showed ¼. Trans pan--------------------------107°f-----106°f Trans out line-----------------------137°f-----129°f Trans return line--------------------129°f-----124°f SSM Water temp--------------------145°f-----144°f SSM Trans temp---------------------91°f -----95°f Bottom of head---------------------144°f-----145°f Header with shield removed----------346°f-----346°f Bottom of radiator-------------------122°f-----118°f Lower hose-------------------------119°f-----117°f Upper hose-------------------------124°f-----120°f Top of engine block-----------------128°f-----133°f Upper intake manifold---------------100°f------98°f Note; Silla radiator, AC on, garage temp 80°f.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 07-31-2008 at 11:45 AM. |
Re: Transmission and radiator temps.
What do you see as the reason for the 30* difference in the pan temp? Is it possibal that it's due to heat radiated from the Y pipes? And then another ~40* difference to the SSM Trans temp??? On the inlet and outlet temps were you shooting the metal line or rubber line? And the biggest question I have is how do you type a degree sign??????
Alt + 248(on the num pad) = °
you say thermstat removed so it could be running cooler than it should ?
Oops! The 167°f was a typo! The rest of the numbers are (now) correct. The car was not driven, just started and allowed to warm up on the lift in park. On the inlet and return lines I was shooting at the metal lines. Hold "alt" 0176
Yes, and later I'll run it again with a factory thermostat.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
Tom is this my car your playing with again
1995 POLO LSI 76K MILES SOLD |
Playing with?! It's all I do, Wake up, work on Dans car...
Go to sleep, dream about working on Dans car... Wake up and sleep/work on Dans car... The only good news is that I have been charging $35.00 an hour since 2007.
Once you know the ASCII codes, you can put all kinds of nifty symbols in your posts. I use Ø all the time at work (Alt + 0216).
Diana 1992 Liquid Silver LSL, >230K -- "Silver Bullet" // dimpled/slotted rotors, SS brakes lines, 5000K HID headlights // TRI-TONE paint |
dcb |
Thread Tools | |
Display Modes | |
