Old 07-22-2008, 05:02 PM
processengr's Avatar
Recommended parts for 4.44 installation
Hi all,
Looking to put 97 Leggy Outback (4.44) trans. in daughters 92. Thinking would want to change flex plate, front diff axle seals, trans TQ seal, drive shaft U-joints (by driveshaft specialist) rear diff seals...check tranny and engine mounts...what else should I plan to inspect/replace/lubricate?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-22-2008, 08:20 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Recommended parts for 4.44 installation
I would check out the rear differential bushings. They usually rot out after many years of New England winters and will cause a clunking in the rear during hard turns if they are worn out.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-23-2008, 09:39 AM
trans filter (internal) and pan gasket. I would replace the rear diff axle seals but not mess with the pinion seal.
Also the front diff axle seals require the removal of the screw in backlash/preload adjusters which can throw things out of whack, which is not recommended for someone who is not familiar with them.
I would suggest replacing the cooler lines for the trans as well as all their clamps to be sure they do not give you any trouble in the future.
Old 07-23-2008, 10:31 AM
A small diameter seal spring(?) was hanging out of the front diff on one side...Could that spring be replaced without removing seal?
Cheers! Gordon
2018 Tesla M3 30k
Old 07-23-2008, 10:40 AM
i would replace them then just for safe measure
Old 07-23-2008, 04:24 PM
The spring...any chance this didn't come out of the diff seal?
Cheers! Gordon
2018 Tesla M3 30k
Old 07-24-2008, 07:47 AM
It looks to be a little large to be that seal BUT I wouldn't rule it out. Replace them both if you have to do one
