Old 07-18-2008, 02:09 AM
RoughSilver92 RoughSilver92 is offline
Fast turn signal, bulbs working
My right side turn signal flashes faster than it should, as if a bulb was out, but both bulbs are working. Any ideas
Old 07-18-2008, 04:37 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Fast turn signal, bulbs working
One of the bulbs provides a resistance greater than what the car is expecting. I would try swapping the bulbs from the other side of the car to see if that stops it - then you'll know which one is the culprit.
-Jason
-Obi Wan Kenobi
Old 07-18-2008, 01:31 PM
kwren's Avatar
kwren kwren is offline
Or maybe just replace them with new bulbs if you are going to take them out?
Just a thought...
Keith
Old 07-18-2008, 02:20 PM
Just a thought...
Keith
yea, not worth it to try and find a bad bulb... buy new ones, they are cheap and you will then know they will be good for a while
Old 07-19-2008, 05:15 PM
Yeah, I already replaced the front b/c I say it was dual filament and thought that even though it was flashing maybe the other filament was burnt and should be blinking also.
I have the bulb to replace the one in the rear, so I'll have to do that when I get it back from the body shop in a couple days.
We only have one flashing bulb in the rear, correct?
Old 07-19-2008, 09:55 PM
kwren's Avatar
Maybe
Old 07-19-2008, 09:58 PM
kwren's Avatar
I think only one filament is used on each bulb... front and rear for flash. Other filament in each bulb is irrelevant.
Pretty sure.
If I have a problem, I just change the bulbs. If it persists, would change the flasher.
Keith
Old 07-19-2008, 10:22 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Part the car out.
Brian
Old 07-19-2008, 11:05 PM
kwren's Avatar
Originally Posted by Ricochet View Post
Part the car out.
you forgot the...
