Old 07-08-2008, 09:32 PM
stanbu815 stanbu815 is offline
Really Senior Member
AC/Heater problem
Have a 96 w/93K miles. Bought it in 2002 and never had any heating or AC problems. I live in Chicago. Sometime early Spring 2008, I noticed that the Temp Control was not adjusting the temperature but I was getting enough heat to at least keep the car comfortable. It was getting warmer outside so I avoided doing anything. In May, I tried the AC for the first time since last year's cooling season and it worked fine except I couldn't control the temperature even adjusting the control from max to min temperature. However, ever since May, the compressor often doesn't kick on until after a few minutes but once it is on, it stays on and I freeze. When it won't initially kick on by pushing AUTO, I try DEF and it won't kick on with that setting either. It does not appear to be a compressor or refrigerant problem but rather a control problem. There is no check light on.
I read about Sensor failures. Could that be an issue? Remember, the Temp Control stopped working first and unless the Sensor controls the Temp Control, I didn't see that as a problem but who knows? I also read about a Control unit that gets stuck. Could that be the problem?
Anyway, before I go to my favorite mechanic who is not an SVX expert but has done good work for me, I thought I could give him an idea of what to look for.
Can anyone help me?
Thank you,
Stan
Sold 92 Pearlie in 2002 and 96 Polo in 2009, both to Earl Steele. Currently driving 2004 Acura TL
