check engine code 21
I am getting an intermittent check engine light for code #21, which I believe is for temperture sensor for the cooling system.
I can not get the search function to work. What typicaaly causes a code #21? Is it hard to replace the sensor and are there some pictures of where the sensor is located? Thanks in advance! Ken |
Re: check engine code 21
Code 21 is the Coolant Temperature Sensor. It's a small, about ~$25 sensor that is located under the Throttle Position sensor. It's on the driver's side near the back of the engine block on the top. It's easy to replace. It's a brown color and requires a deep socket 19mm to remove. Get the new one, quickly pull the old one, and replace. It's rather easy.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Change that sensor soon! My light also came on and off and I didn't pay much attention to it until it came on and stayed on, then I had a hard time starting the car. Replaced the sensor and still had a hard time starting the car until I "CLEARED THE CODE". Make sure you clear that code after you replace the sensor.
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
Thanks for the replies.
I was going to get the part from Checker but it was the wrong part I believe. It was small, with a single snap on connector which is used for a gauge. Is there possibly 2 sensors to replace or just 1. Is this a dealer only part? Thanks, Ken |
Yes there are 2 coolant sensors, they are right next to each other. Manarius had the description right for the one that sends the signal to the ECU. The one you got from Checker only has one wire and it feeds the signal for the dash gauge.
I think you can get them from most places, I know I got some from Rockauto.com, but I think the dealer price is real close or maybe lower than some aftermarket suppliers.
