Old 07-03-2008, 11:38 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Re: sunroof won't open
Tighten the "clutch" on the sunroof motor.
Pop the little plastic cover off of the roof liner, when you look up there you see a nut with a metal washer bent around it.
Unbend the washer and tighten the nut acouple turns, bend previsouly mentioned washer back into place.
Now you should have a great working sunroof (also suggest that you clean out all the tracks and lube everything up while you're at it).
Dustin
-Dustin
Old 07-04-2008, 11:01 PM
robinhoodof she robinhoodof she is offline
"WOW" I CAN SEE.....IT'S A MIRICLE LOL Thanks Keith this will help...Chris
Old 07-04-2008, 11:03 PM
Thanks, did'nt know this, I've got a black 92 & if the sun roof moves slow on that one I'll know what to do. This one has NO power to the switch!...thanks...Chirs
Old 07-05-2008, 12:03 AM
kwren's Avatar
kwren kwren is offline
Originally Posted by robinhoodof she View Post
"WOW" I CAN SEE.....IT'S A MIRICLE LOL Thanks keith this will help...Chris
So sorry did the first one in a big rush and didn't have my glasses on
Take care,
Keith
Old 08-13-2008, 04:32 AM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
I know this is an older thread, but wanted to say thanks to SURTEES for the tip.
Originally Posted by SURTEESS View Post
Mine did that a few years ago - so spent about 2 hours!! cleaning ALL the rails then spaying a CRC lube into all the places (wipe away excess so that is does not get into head liner or paintwork).
The person I bought the car from thought having to press the button twice to open it was a fault and told me of the 'give it a bit of a nudge' thing. Between finding out through a Subaru TSB that nope, it was meant to work that way and this thread, I now have a perfectly smooth opening sunroof.
Like SURTEES it took quite a while to clean. Eventually found moving it along the tracks every now and then dislodged bits of gunk I couldn't get to. I think it'd probably pay to do it again shortly 'cause I can already see more old bits of ick that've been dislodged.
Again, Thanks.
Tania.
