Old 06-23-2008, 04:40 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
Proper use of jack stands?
I've always just used my old 2 ton floor jack for wheel changes and ramps for any time I venture under the car. But I hear lots of mention of jack stands as the safer way to do some things and if more than one wheel needs to be up in the air they are the only solution (without a lift of course).
So what's proper jack stand etiquette?
Where do you place them? At the indented jack points on the frame rail? Or somewhere else?
Should they always be used in pairs, like 2 in the front or 2 in the back? Or can you just do 1 wheel? Or should it be all 4 always? Or is all 4 even suggested?
Sorry, maybe dumb questions, but don't want to hurt my car or myself.
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 06-23-2008, 08:40 PM
immortal_suby's Avatar
Thread Killah
Re: Proper use of jack stands?
It would probably be a good addition to our how-to section to have a safe jacking/ jackstand location map/picture
I use the frame rails in front (don't know what they're called but I call 'em frame rails - the meaty pieces sticking out from the floor/unibody) and in the back the rear diff to lift it with the floor jack and the 2 spots where the rear suspension arm (don't know what its called) mounts forward of the rear wheel with the 2 bolts for the jackstands.
Locker Link
2015 BRZ Limited 6MT
Old 06-23-2008, 09:28 PM
The best place for the stand is where you are to use the stock jack. There are 4 ridges under the cladding, 2 on each side. Jack the car up using the subframe under the engine behind the oil pan and under the rear differential for the rear. I used normal 2 ton jacks for years but got turned onto a 6ton Truck jack that is about 4' in length with a 4 foot t-bar handle.. It reaches under the car with ease on both ends and can lift the car up to 32". Not recomended for the occasional user but for someone like me, the big jack was great. Also 6 ton jack stands on each corner make the car more stable and safe, not to mention they hold the car up to every bit of the 32" the jack would put it up
Old 06-24-2008, 07:07 AM
Mr. Pockets's Avatar
Moderator
I don't use the jack points because my stands have deep cradles on them and would bend the sheet metal. The last time I jacked up the SVX was last year for the brakes, and to tell you the truth I'm not certain where I put them.
I just try to find anything 'solid.' I like suspension or subframe mounting points, frame rails, etc. Where I put them depends on what I need to work on at the time, but I like them to be as far apart as possible.
I use stands either in pairs or on all four corners. If I have to get well under the car I usually just do all four corners instead of lifting one end up real high. I never use one stand at a time under one corner.
Since the SVX is pretty low, I park it on boards before I jack it up, and if I need to get it up high sometimes I have to raise it in steps.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-24-2008, 07:41 AM
joe62890 joe62890 is offline
SVXless
I usually just put them on the frame rails. I've got stands with deep cradles in the them and have never had a problem out of them. Jack the car up in the front on the subframe jack spot (2006 RSX). Never had a problem. I'm still afraid to get under there sometimes. I think it's time for new jack stands.
1991 Nissan 240SX - Built, disassembled, and sold.
Old 06-24-2008, 09:18 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
I had the same problem initially, but a grinder does wonders. Just a little contouring of the cradle without reducing its strength permits use in the spaces designed under the frame. It was 20 minutes well spent to slightly modify the cradle of my four stands.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-25-2008, 12:26 AM
Hondasucks's Avatar
Subaru Technician
yeah, definitely use jack stands, jacks are designed to LIFT a load, not support it, and if the O-ring blows out, that sucks, especially if you are under the car when it happens. Always use jack stands in pairs, one stand is not very stable and the car could fall off.
1986 VW Jetta
Old 06-25-2008, 12:54 AM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
6 ton jack and stands sounds godly *searches ebay...
-Nate
'92 LS-L Pearlie
Old 06-25-2008, 08:00 AM
Was MacGyver
Thanks for the advice everyone!
Matt is right, a short write up and diagram would be a useful addition to the How To section. Safety should always be rule #1.
Troy
Old 06-25-2008, 09:15 PM
When using jack stands and or jack, sometimes it is necessary to utilise a point which is flat and smooth, whereby limited friction is present.
In these circumstances I always put some wood between support and supported, so as to provide friction and grip. This also prevents excessive loading on any existing high point.
Old 06-26-2008, 09:56 AM
Moderator
As nice as that sounds, I don't think I'd put up a How-To without a very strong disclaimer.
2005 Outback
END OF LINE
Old 06-27-2008, 05:22 PM
Was MacGyver
It can go both ways. I mean certainly getting the car up on jack stands can be dangerous and not something we'd like to encourage.
But at the same time, not putting out a strong suggestion that for certain jobs jack stands are a MUST over using your floor jack to support the car for long periods? And if so, then suggestion on proper and safe placement of the jack stands would be good.
All in all, just about every How To document should have a clear disclaimer at the beginning. Some stressing safety concerns. All of them stressing that these are do at your own risk and the network and it's members are not liable for damage or injury.
Troy
