Old 06-15-2008, 08:47 AM
Tremec Tremec is offline
Re: "While you're down there..." Suggestions?
Thanks, exactly what I was looking for!
Old 06-15-2008, 08:58 AM
Speedklix's Avatar
Locker Link Solution
BTW, Advance Auto Parts uses the same part # for their Bosch front and rear O2 sensors.
#13250
Tom, are you pointing this out because he needs a 3rd?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 06-15-2008, 09:34 AM
Knightwulf's Avatar
Knightwulf Knightwulf is offline
I think he is because I requested information on where to find one earlier in the thread.
#13250
Is the same true for the Walkers I picked up? Or do I need to spend another $100 on the Bosch to get a rear replacement?
Thanks again for all the advice, gents!
'97 Ebony Pearl LSi (Luna) 111,000 - Sold to 1986nate
'09 Obsidian Black Pearl Legacy GT Ltd. (Raven) 028,000
Old 06-15-2008, 09:52 AM
Knightwulf's Avatar
If I had the engine or transmission out, and both the time and the means,
I would change out the engine rear main seal, reseal the separator plate,
the engine intake manifold gaskets, the under manifold gaskets, all of the under manifold hoses, the valve cover gaskets, but all of this takes time, and time = money.
What is your budget?
#13250
Are there 'seal/hose kits' I can pick up? Or do I need to scout out each part individually?
I've been using Rock Auto for a lot of these parts so far... I've been very impressed by their prices, selection and shipping costs/speed.
As for budget, I have some leeway, and with everything I'm looking at having done, I'm seriously consdering having an actual SVX guy do everything beyond the transmission (everything else I can throw in my trunk and drive there... Not so much with the tranny...).
Rock Auto also has some selections for tranny coolers, that they say will fit the SVX, and I'm wondering if they have any advantage over the B&M 70268 I've seen suggested elsewhere. All six options are manufactured by Four Seasons.
