Old 06-07-2008, 12:41 PM
racecube racecube is offline
Fuse for Windows and Roof
Hi There,
i can't find the Fuse for the electric Window and the electric roof. SVX Handbook from Subaru doesn' tell. Maybe anyone knows...hope its not a problem that my car is from Germany and everything is different??
greets from Eddy
Old 06-07-2008, 03:34 PM
redlightningsvx's Avatar
Collision Refinishing Tech
The fuse is either under the hood or behind the kick panel near your feet. I can't remember which one so check both.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-07-2008, 03:48 PM
kwren's Avatar
kwren kwren is offline
U.S has...Actually one of each and a cirket breaker!
Originally Posted by racecube View Post
Hi There,
greets from Eddy
A 10 amp located under left side of dash. "hot on ignition switch on or start" ... For the relay
a 30 amp "hot all the time" located in main fuse box in left side of engine compartment.
A circuit breaker located under the drivers seat.
The power window relay is also located under the drivers seat.
Best I remember there was a slogan "We make it simple"
Oh, right, that was for Honda.
Good luck,
Keith
Old 06-08-2008, 06:32 AM
Hi and thx for the answers: In my car there is no fuse in the fuse box for roof and window but a formerly owner has put a 20 A Fuse in a special holder near to the fuse box. I've replaced and things are workin fine again!
Old 06-08-2008, 12:19 PM
94SubieSVX's Avatar
OOC for a while
Take the driver's seat out and tucked underneath the carpet you'll see a 10 or 12mm bolt. Take that bolt out and there's the relay for the windows/sunroof, also there's a fuse on the same bracket. Try cleaning up the contacts first because they tend to get corroded.
bLAh
